Sponsored by: Innova
Vss. Tap
Old Jun 3, 2009 | 05:33 PM
b2747's Avatar
b2747
Talking Vss. Tap
Started to install my new Pioneer F-90BT in my 98 F150. Where would be the best place to tap in for the VSS signal? I don't want to degrade the signal to where it doesn't work properly. Any help would be a ++++++++.
Thanks guys
Old Jun 4, 2009 | 12:48 AM
chiahunw's Avatar
chiahunw
Check this website: 98 F150 Cruise Control Wiring
Hopefully this would help.
Old Jun 5, 2009 | 01:59 AM
cartmanea's Avatar
cartmanea
I just installed an F90BT as well, didn't have time to hunt down the VSS signal, but plan to do it in the future. I've heard, however, it doesn't make much difference since it gets it form the GPS.
Old Jun 7, 2009 | 12:32 PM
b2747's Avatar
b2747
Talking Vss tap
I just spent a hour on the phone with a Pioneer Engineer. He was full of information on the F-90BT. He asked why do you think Pioneer put the connection in the harness if it wasn't needed? He was very helpfully and to call him direct if I needed any other question answered. I think it is great when a Pioneer Engineer will take the time to talk to a consumer for a long time. I would buy Pioneer again.
Old Jun 7, 2009 | 12:36 PM
b2747's Avatar
b2747
Talking Vss tap
Forgot to tell you that you can tap into the VSS wire (BLACK&GRAY) at the cruse control, I think yours is on the left fender well near the shock tower.
Old Jun 7, 2009 | 12:38 PM
cartmanea's Avatar
cartmanea
You can find it at the instrument cluster too I believe.
Old Jun 7, 2009 | 12:45 PM
b2747's Avatar
b2747
Talking Vss tap
Thats true but why pull the instrument cluster to get at it?
Old Jun 7, 2009 | 01:02 PM
cartmanea's Avatar
cartmanea
You don't have to pull the cluster, just find the harness under the dash that its in. Why run another wire through the firewall if you don't have to? I'd rather tap a wire in the cab than outside where it is more exposed to the elements.
Old Jun 7, 2009 | 01:26 PM
b2747's Avatar
b2747
Talking Vss tap
GOOD THOUGHTS. THATS ONE I WILL CONSIDER WHEN I GET TO THAT POINT ON MY INSTALL OF MY PIONEER F-90BT. THANKS FOR THE INFO.
Old Jun 11, 2009 | 10:46 AM
b2747's Avatar
b2747
Talking Reverse Wire
Where are you tapping in for the reverse wire? Are you going to use the backup light circuit?
Old Jun 11, 2009 | 11:18 AM
cartmanea's Avatar
cartmanea
Yeah, that seems the easiest.
rsx664
Jun 1, 2010 10:37 PM
inter286
Electrical Systems/Wiring
Apr 14, 2004 12:13 PM
squidix9
Aug 23, 2003 11:35 AM
leadmic
Jun 11, 2003 12:42 PM
leadmic
Computer Chips & Tuners
13
Jun 9, 2003 08:46 PM
