Computer Chips & Tuners
VSS signal ?
Old May 28, 2003 | 02:23 PM
leadmic's Avatar
leadmic
VSS signal ?
Im installing a 97 460 engine, trans, and transfercase into a 73 crewcab. The problem Im running into is the speedo and VSS drive( the 97 uses a VSS in the rear end) . What I would like to do is install a transfercase from a 89-91 F-250 for a speedo and VSS drive. Ford used a VSS with a cable drive comming off it in thease years. What I need to know is the signal from the trans or transfercase mounted VSS the same as the rear end mounted VSS signal?
Thanks in advance for any help
Leadmic
Old May 29, 2003 | 04:57 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
One signal is used for anti-lock brakes (high pulse), the other for speedometer (low pulse rate)/shift. Even with a Truspeed you couldn't modify the pulse rate enough. You'd need a 555 chip or 74LSxx (don't remember the exact number as its been a while since I worked with TTL logic) as a multiplier/divider. If you go this route you may want to see if you can get a multiplier/divider at JDR Microdevices as you'll be able to wire it in without having to know the low level stuff. Let me know and I can look up the pulse rates for you.
Old May 29, 2003 | 06:37 PM
leadmic's Avatar
leadmic
VSS signal ?
Hey Ken, all I can say is Wow. I think Im going to have to learn some things if I want to complete this project.
Ok first off which chip are you speeking of and how will I know which one to get? I probbly will need the pulse rate. It still sounds easer than changing the rearend and the transfercase.
I thank you very much for your help Im a little over my head with the electronics in the case.
Leadmic
Old May 31, 2003 | 06:44 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
You don't want to use a multiplier/divider chip unless you're familiar with electronics. Basically, they take a pulse and divide or multiply to get a new pulse rate.
Do a web search on www.google.com for "automotive pulse divider" and you'll find a wide range of "turn-key" products that will do what you need. I believe Steve posted the pulse rates elsewhere so you can use those numbers when selecting a pulse divider product.
Old May 31, 2003 | 07:06 PM
Bob Ayers's Avatar
Bob Ayers
VSS signal ?
A 555 is a timer chip, the chip you want is a binary counter.....
Old May 31, 2003 | 09:23 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
Its been a long time since I did any TTL (used to have a lot of fun putting together ISA interfaces!). Man, I miss some of the cool Z80 stuff! A counter is a divider (ie, 1 pulse out for every X in). Not in the sense of a ALU divider or a divide register though.
Old May 31, 2003 | 09:26 PM
Bob Ayers's Avatar
Bob Ayers
VSS signal ?
Z80.....Ken, your age is showing.....lol!!!!!
Old May 31, 2003 | 09:32 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
Used to love the instruction set! It had two identical register banks that you could switch between with one instruction. Really cool for multi-tasking on an 8 bit CPU....
Old Jun 2, 2003 | 12:44 PM
leadmic's Avatar
leadmic
VSS signal ?
Good stuff, but back to the problem at hand. Is this possable? If so how? Which chip? Thanks for any and all help.
Leadmic
Old Jun 3, 2003 | 01:42 PM
leadmic's Avatar
leadmic
VSS signal ?
Hey Ken & Bob where did you go? Please dont leave me hanging. I need your help on this one.
Thanks Leadmic
Old Jun 3, 2003 | 01:53 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
Do a web search on www.google.com for "automotive pulse divider" and you'll find a wide range of "turn-key" products that will do what you need. I don't have specific product in mind, there are several that will meet your needs with a web search.
Old Jun 3, 2003 | 06:10 PM
leadmic's Avatar
leadmic
VSS signal ?
Thanks so much for the help Ken. I looked it up and found two companys that look promissing.
Leadmic
Old Jun 4, 2003 | 04:48 PM
leadmic's Avatar
leadmic
VSS signal ?
Hey Ken , I got to thinking about it and dont I need a pulse multiplier rather than a divider? I need to increase the pulse not decrease it. Do the make such a thing? I did a search and came up empty. Any ideas?
thanks for your help.
Leadmic
Old Jun 9, 2003 | 08:46 PM
FTE Ken's Avatar
FTE Ken
VSS signal ?
Try: http://www.t-m-ingbuero.com/main.html
BrettMavriK
100
Jan 14, 2018 11:08 AM
Quik
May 20, 2015 08:54 PM
460
Offroad & 4x4
May 14, 2012 06:17 PM
jarod17
Testing.....
Jun 28, 2011 10:57 PM
rsx664
Jun 1, 2010 10:37 PM
