Toploader to replace C-6 on 460
Old Mar 18, 2002 | 11:11 PM
FlowmasterMan's Avatar
FlowmasterMan
Could a Toploader 4-speed standard replace a C-6 auto on a 77 Ford truck with a 460??? I was wondering and does anybody make a kit or instructions for this swap?
Old Mar 18, 2002 | 11:51 PM
lshort's Avatar
lshort
Yes this is a easy swap get a bellhousing from a 351m/400/460
find a 73 to 79 with a stick to get the pedal and linkage from
dont forget to put in a pilot bearing.The top loaber is a good choice.
may haft to alter drive shaft lenght.
larry
Old Apr 23, 2002 | 06:44 AM
DeenHylton's Avatar
DeenHylton
Adding to what Larry said...you'll also need the manual flywheel and the big-block top loader. The input shaft for the big-block is larger in diameter and only comes in a close ratio. The small block top-loaders were available in close and wide ratios. Deen
Old Apr 23, 2002 | 07:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Fellenz
Jun 10, 2015 08:14 AM
BigBlockGuru
Oct 10, 2014 09:19 PM
ford1940deluxe
Aug 5, 2007 11:25 PM
brown79
Jul 22, 2005 12:03 AM
