c6-to toploader swap
Old Jul 19, 2005 | 09:38 PM
brown79's Avatar
brown79
i have a 1979 f150 460 c6 i want to install a toploader 4 speed.
i have a 1979 f250 400 np465 to use as a parts truck.
i have heard that some 6 cyl trucks used an overdrive variant of the top loader will the mounts and driveshaft from one of these trucks work?
Old Jul 20, 2005 | 02:11 PM
85e150's Avatar
85e150
They seem be the same. Go here and look all around the site regarding toploaders. Gearing is not great for a truck, and you do want the wide ratio.
http://www.davidkeetoploaders.com/imposters.htm
I'd spend more and get a later model 5 speed:
http://www.moderndriveline.com/
http://www.ttcautomotive.com/English/products/T-56.asp
or keep the C6 and:
http://www.gearvendors.com/
Happy motoring.
Old Jul 21, 2005 | 12:16 AM
brown79's Avatar
brown79
thanx for the tip's i want the toploader because its the classic big block and a four speed combo if its a little sluggish than i will just add an extra couple of hundred horsepower :-) to compensate
Old Jul 21, 2005 | 01:48 PM
Txquadhunter24's Avatar
Txquadhunter24
One problem The OD trannies found in the trucks won't handle the power of a big block if your gonna use it hard.
But the 3spd with OD's can be found behind 302's too. up until 86. My 86 F150 has one. Even though I only have a 302 in mine it's a fun ratio tranny. If it would hold to the big block power it'll be a blast!
Old Jul 22, 2005 | 12:03 AM
85e150's Avatar
85e150
The 4 speed OD trans based on the top loader is not as strong as a top loader. The top loader link I listed shows some of the differences.
ZF's will take quite a bit of torque, but I doubt you could shift one very fast.
You enjoy yours because your 302 will rev far enough to overcome the grand canyon between 2nd and 3rd. Us 6 cylinder boys hate that gap, as the six won't wind up far enough to cover the gap.
Of course, you could put in the top loader AND a Gear Vendors OD...that would be quite a set up.
PRUSue
Aug 31, 2016 11:34 PM
Fellenz
Jun 10, 2015 08:14 AM
401477534
Mar 10, 2011 09:39 PM
Kirbys73F100
22
Nov 3, 2009 11:04 PM
obey_your_master
May 2, 2006 08:59 PM
