7 wire harness missing wires
Old May 30, 2009 | 08:14 PM
erwatt's Avatar
erwatt
I recently purchased a 2000 Excursion. One of the reasons I purchased the X was to haul my camper. Hooked up the camper today and I didn't have brake or turn signal on one side of camper. Traced it back to the X and found I am missing 2 wires for the 7 pin connector plug. The red and black wires have been cut and apparently removed? Anyway, I know where the wires terminate (at the plug), but where do they originate? Do they come out from under the dash?
Old May 30, 2009 | 10:10 PM
c.f.moore's Avatar
c.f.moore
I believe that if you trace the wires from the plug back towards the frame, you will find a connector close to the frame rail. You can buy the short pig tail from that connector down to the plug, thus regaining the 2 missing wires.
Good luck
Old May 30, 2009 | 11:01 PM
erwatt's Avatar
erwatt
Good luck
Sorry, I didn't go into enough details. The wires that have been cut and removed are not on the short pig tail. They are wires that feed into the connector close to the frame rail. So, the question still remains, where is the other end of these wires, where do they come from? Any help would be greatly appreciated!
Old May 31, 2009 | 10:29 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Re-read what he said: "You can buy the short pig tail from that connector down to the plug, thus regaining the 2 missing wires."
So IF all the wires are at the frame rail, connecting a NEW pigtail will give you your connection again at the rear......By the time you posted that, you must have been tired...hey, we all do it....
Old May 31, 2009 | 11:00 AM
Ford_Six's Avatar
Ford_Six
Red and black are aux power and back up lights. You have a problem on the yellow wire for the left, or green wire for the right. It's also possible you have a bad bulb or socket.
Old May 31, 2009 | 04:02 PM
grafekie's Avatar
grafekie
Fuse?
Red and black are all too commonly skipped... its a shame, especially coming from the factory, but most people never notice.
Old May 31, 2009 | 06:48 PM
cdrmotorsports's Avatar
cdrmotorsports
Ford_Six is correct. The green wire is for the right turn and right brake light. The yellow wire is for the left turn and brake light. I'd check the fuses under the hood. There whould be seperate fuses for left and right turn/stop. It should be listed as TRL left turn/stop (TRL right turn/stop) or seomthing like that. The manual will tell you where to find it.
heyyou325
Electrical Systems/Wiring
Jun 9, 2013 09:20 PM
sedwardson
6.7L Power Stroke Diesel
Jun 10, 2011 09:56 PM
erwatt
Jun 1, 2009 01:50 PM
planchonse
1997 - 2003 F150
Jul 16, 2002 01:31 PM
solidaxle
Mar 4, 2001 10:56 AM
