Head Gasket Writeup: 7.3 IDI ?
Old May 30, 2009 | 04:36 PM
fozzy's Avatar
fozzy
So yeah I have to replace head gaskets in the 1989 7.3 idi, I am seeking an online writeup or is it just remove/replace/reverse procedure?
Anything I should look out for? I am going to have the heads magnafluxed and tanked, replace glow plugs (ZD-9), OEM stat, and all interval stuff (fuel/oil/air filters etc). I will be doing this in my driveway with no lift or anything. I have done heads and gas engine replacements. Seems like everything in a diesel is greasy and heavy
Am I going to need a valey pan or intake gasket if so where can I get it? AZ did not list one. It says not included thats all.
And what kind of coolant for these engines and how much?
Thanks WAAAAY in advance.
Old May 30, 2009 | 09:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
As for the parts Advance Auto lists what you will need.
Intake Manifold Gasket Set - Advance Auto Parts
Cylinder Head Gasket Set - Advance Auto Parts
Passenger side head is a bear, you can't get several of the bolts out, you have to put fuel line around them to hold them up in the head till it is out.
Same bolts must be in the holes held up with fuel line before the head is put back in place.
Other than that, right much a standard remove and replace, just more head bolts and much heavier parts than you would find on a gasser.
Have you done gas engine work before?
Old May 30, 2009 | 09:35 PM
fozzy's Avatar
fozzy
yes I replace my engine before, swapped cams, etc etc and done cylinder head replacement before on ford gassers.
WHat do you mean using fuel line to hold bolts while removing the head? Is there a fuel rail on the head I use for this or just any old rubber fuel line to remove?
Also of importance, I understand I do not want to mess up some timing marks on the fuel pump?? I do not know what this means and where would I scribe my marks so I do not lose timing?
Old May 30, 2009 | 10:23 PM
David85's Avatar
David85
You need to remove the bolt torque in the reverse sequence of tightening, rather than simply pulling all the bolts in a random easy to reach fashion.
I've heard you can reuse the intake manifold gasket/valley pan if you clean it well (but no harsh solvents) and use RTV sealant. Some have done this several times, or so they claim. If I ever have to pull my intake again, I will try it myself because those things aren't cheap.
Old May 30, 2009 | 10:35 PM
fozzy's Avatar
fozzy
heh I will try that!! $65 in the bank I have sliced my finger wide open trying to remove one before though. I Just printed a torque sequence page and misc drawings from AZ.
Are there any special tools needed to remove fuel injectors, lines etc? I have a pretty good and stocked MAC tools cabinet
Old May 30, 2009 | 10:51 PM
David85's Avatar
David85
I can take the injectors out with nothing other than an open end wrench. A 1" deep socket would maybe be better, but I never needed one. Ideally, you would use special fitting wrenches (5 point open end, or crows foot, I think they're called??) for the actual fuel fittings but again, a regular open end worked fine for me.
Remember to remove the injector pump with the fuel lines as one assembly, but to leave the drive gear and housing in place on the engine.
Old May 30, 2009 | 10:58 PM
Dave Sponaugle
Since you can not get the bolts out of the holes in the head, you use a short piece of fuel line split down the side to slip over the bolts and hold them up in the head.
That way the thread portion on the bolt is not catching on cylinders and water passages as you move the head off the block.
65 dollars is cheap compared to doing the job again because of a leak.
The shape mine were in by the time they were off, I would never trust them.
I had enough trouble getting a new one to seal.
But then I am running a bit more boost than most people are.
Old May 31, 2009 | 09:21 AM
fozzy's Avatar
fozzy
It occured to me what you meant about the fuel lines last night. About how high do you need to hold them up? about 1"?
Yeah if the valley pan looks pad I would change it too.
When I remove the injector pump, am I going to mess with some sort of timing marks? IS this where the drive gear and IP need to be timed together?
Thanks
Old May 31, 2009 | 11:04 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
IP R&R Steps
-Enjoy
fh : )_~
Old Jun 2, 2009 | 06:25 PM
fozzy's Avatar
fozzy
Ok I have almost got to where I can pull the intake and heads. I did not remove the oil filler housing, is this ok? I also didnt make any marks on the housing where the IP meets. I couldnt see where to do it and by then IP was in my hand
I will not move the crank during head gasket change, nor will I move the pump hub (i did make some marks there to make sure it doesnt go out) I see that the alignment dowel is there so I should be ok when I start it eh? Or did completely lose timing? I have read how to dial it in once truck is running.
Just wanted some assurance I didnt mess this up already
Old Jun 2, 2009 | 09:15 PM
Dave Sponaugle
As long as the IP drive gear and cam gear stay meshed, you will be fine.
The alignment dowel will get the IP back in time close enough to run if you line up the timing marks on the IP neck and the gear cover.
Fine tuning the timing by ear is not that hard.
Where everyone messes up is pulling the four bolts that hold the IP drive gear cover down, then removing the IP, drive gear, housing and injection lines as one piece.
Old Jun 3, 2009 | 11:32 AM
fozzy's Avatar
fozzy
Ahah! I see.
Thank you ver much
Old Jun 3, 2009 | 11:44 AM
Festus Hagen
Methanoholic
I assume there is timing marks on the cam gear as well as the IP gear, is it a sight issue on realigning them. (Can't see the marks on the cam gear without pulling the front off)
-Enjoy
fh : )_~
Old Jun 3, 2009 | 11:47 AM
fozzy's Avatar
fozzy
I removed the front cover (2 bolts) then removed the 3-5/16 (16 pt) and 3-9/16 bolts from around the iip and removed it.
Are you asking if I can timing marks? I cannot see any
Old Jun 3, 2009 | 06:55 PM
Dave Sponaugle
There is a plate behind the water pump that covers the timing gears.
The top of the cam gear is slightly below the top of the timing gear cover.
So seeing it with your eyes is impossible.
Several people have used a butter knife to see the reflection of the timing mark with success, but that just adds time and frustration to the job.
Mark on the crank gear, two marks on the cam gear and one on the IP drive gear.
With the front off the engine all four line up from top to bottom.
