I do not seem to have power to the fuel system no pumps are working fuel tank switch on dash has power but blinks a test light [may b nrml] can start with ether but will not run on it's own. It's an 88 E350 club wagon with 460 any help with where to start is greatly appreciated.
I just fixed a simalar problem on my 85 E350, so that makes me an expert! LOL...NOT
But I'll tell you what I found on mine,may be the same with yours?
I replaced the fuel cut-off relay{easy} after I found it {HARD}
Mine was on the drivers side of the van,under the hood on the inner fender,the green one.Hope this helps.
Reason: Different pic
I haven't worked on my old '89 in 7 years, but if I remember it's located on the pass side, behind the kick panel or above it, behind the knee panel (in cab) at least on the '91+ that's the location.
You'll find it right away, it has a Red button top, just push it down and if it "clicks" that's your problem.
