No Power to Fuel Pump on E350 Cutaway with 460
Okay so I pulled out the Fuel Pump relay (At least I think it is) It was screwed to the underside of the rad support on the drivers side. I took it in to the local autoparts store and since there is no part numbers on the relay they looked on the computer for "87 E350 fuel pump relay" and they had a completly different relay. Theirs had 5 pins and mine has 4. I'm just wondering if I pulled the right one now?? Pics are attached below.
Not likely the Fuel Pump relay as you say you have no power to it.
If you do not have a test light get one as it will make it a lot easier to find the problem as a meter will have you going in circles.
A test light with a bulb in it will load the circuit and a meter will give false readings in the fuel circuit.
First jump out the oil pressure switch and then see if both fuel pumps run when you turn on the key. Also jumping out the oil switch will allow you to trouble shoot the circuit without cranking the engine to check the fuel circuit and running the battery down.
Does the fuel pumps run now when you turn on the key?
By the way you have a 1986 E350, the 1987 was FI.
Use 1986 E350 when buying parts.
Your 1987 Title is for the home part and not the Ford part.
Check your VIN for the year.
Oil switch jumped photo below and is located on the top rear of the engine.
1986 Fuel System RV:
The VIN Sticker from ford says it was built on 4/13/87, and the actual motorhome was built in June of 87. The VIN # for the chassis is: 1FDKE30L5HHB54881
I though they went FI in 87 but guess it was 88. Thanks for the information.
I take it you are saying you only have power on the Yellow wire at the fuel pump relay socket.
Also check the wires under the relay socket for good connections.
The above wiring diagram still apples to your unit.
Have you checked for power on both sides of Fuse #18 in the fuse panel with the key on?
I just checked with the key on and only the wire that is black with the yellow stripe is getting power.
KEY ON:
(These are the wires at the relay plug with the relay plugged in)
Blk/yellow: Has power
Red/ blk stripe: No
All Black Wire: No
Red/ yellow stripe: No
I have a feeling its the relay but all my auto parts stores have a different relay in their system. Even the online stores have the same relay as the local shops. They all have 5 pin's and mine is a 4. This is the part everyone is giving me and it's wrong: http://www.rockauto.com/catalog/moreinfo.php?pk=936884
KEY ON:
Red/ blk stripe: No
All Black Wire: No
