Sponsored by: Real Truck
That Hurt!
Old Jun 5, 2009 | 09:13 AM
Downriver Thunder's Avatar
Downriver Thunder
and the ESOF still doesn't work! New vacuum solenoid, new auto lockers, new hubs. I am thinking there must be a broken line going down but the dash airflow is working right.
Old Jun 5, 2009 | 10:43 AM
cartmanea's Avatar
cartmanea
Did you replace the hub seals? My ESOF quit this winter and after doing my gears and balljoints and replacing all the front seals it works again.
Old Jun 5, 2009 | 10:45 AM
Downriver Thunder
Everything was new. I have to dig out my vacuum tester and test the lines. Nice weekend project.
Old Jun 5, 2009 | 11:01 AM
cartmanea's Avatar
cartmanea
I mean the big seal and large o-ring that goes behind the wheel bearing, were the wheel bearing units pulled?
Old Jun 6, 2009 | 08:57 AM
Downriver Thunder
Yah, they are new. I had everything replaced.
Old Jun 6, 2009 | 02:44 PM
mongo75's Avatar
mongo75
It should be called PITA not ESOF.... It could be a small crack in on of the lines, the pump could be bad, a improperly installed o-ring.... On mine, after I replaced all 4 ball joints and all ESOF crap, it loks, but the damn solenoid won't open to release the vacuum, so they stay locked until I disconnect the air line and you hear the hiss.... I hate this system...
1983F1503004x4
Mar 5, 2013 11:57 AM
RM2738
6.4L Power Stroke Diesel
18
Feb 6, 2013 08:42 AM
Jeff Lambert
May 12, 2009 02:51 PM
re_fill
1978 - 1996 Big Bronco
16
Jan 16, 2007 12:52 PM
