Offroad & 4x4
tie rod ends
Old May 29, 2009 | 12:06 PM
northernmoose's Avatar
northernmoose
tie rod ends
well the last parts i need for my sas swap is the tie rod ends, and they want 200 each and there is 4 on the dana 60. Can i use the steering from my dana 50 for the time being? i really dont want to spend 800$ on tie rod ends, is it this expensive in other places (i am in northern British Columbia) so will my steering from my dana 50 work for the time being? both axles are from 1994 trucks.
Old May 29, 2009 | 04:24 PM
Ronin4x4's Avatar
Ronin4x4
If this is a dana 60 swap hog the arms out so you can use one ton chevy tres. Way way cheaper and its what most everybody does anyways.
Old May 29, 2009 | 05:12 PM
75F350's Avatar
75F350
If you use the chebby TRE's you will have to change the tapper on the the steering arms / knuckle and pitman arm and such.
There is no way that these ends should be 200 bucks each.
This is a left hand thread 2027L and it was about 40 bucks:
Old May 29, 2009 | 06:59 PM
northernmoose
i didnt realize you cant press them out, i only had to buy the drag link, which was only 80$ thanks to company discount. Very expensive up here compared to online though
Mrhollywood82
Oct 24, 2016 09:19 PM
AKHunter93
21
Aug 19, 2016 01:10 AM
brennanforgeron
Apr 8, 2016 08:56 AM
Svslow
Oct 13, 2015 07:00 AM
78fordman
Feb 23, 2004 11:43 PM
