Offroad & 4x4
diffs
Old May 28, 2009 | 08:02 PM
rustee90-150's Avatar
rustee90-150
diffs
hey guys im new to the 4x4 forum.
i have a 89 full size bronco i want to upgrade to solid axle. would a d44 with leaf be ok up front and a d 60 out of an f250 be ok in back i duno the yars yet i will soon . is this gona be a ridiculous huge job ? i know its big and what am i gona need to get to do this as in parts mounts ect ? they both have 4.10 s i wana run 35's that gear gona work my engine is stock 302 with aod . thnxs shawn
Old May 29, 2009 | 01:39 AM
75F350's Avatar
75F350
Very good questions. Although, before advice or opinions can be shared, many should know what your intentions are.
You have asked about a D44 solid front axle with leaf springs and a D60 rear axle.
Well,,,,,,,,,,much depends upon which D44 front axle you select, and you might give up the idea of the rear D60.
Your Bronco has an axle that shares the same axle strength as the D60 rear. So other than weight capacity, the rear axle swap would be nothing more than,,,,,,,,,,,,,well there is not much of an advantage.
For the front, if you plan on running leaf springs, then you have your work cut out for you. This frame has no provisions for this, so you will have to be pretty sharp with a tape measure to verify "square".
Coils are pretty easy to keep.
Lets hear what you really want to do with this ride, and then you can recieve some feedback.
Old May 29, 2009 | 05:06 PM
rustee90-150
well my intentions with the bronco are to lift it and use it as a mud truck slash rock crawler nothing huge i just want a big off road truck that i can still drive to work the odd day . so i should stay with my 8.8 in the back? the front diff is out of a 79 f250 with leafs and all mounts and steering links.
Old May 29, 2009 | 05:15 PM
rustee90-150
would i be better to go with a coil spring front axle?
Old May 29, 2009 | 05:19 PM
75F350's Avatar
75F350
ok, know that the D44 steering is much different than the steering on your bronco. The bronco is not capable of using the early push pull style steering, and should you decide to use front leafs, you will run into problems converting the inverted T style steering. Clearances between the drag link and the pass side spring will be tight.
Making spring perches will not be that difficult but the frame widths are different so you will have to make spring perches and hangers for your bronco. This is much easier to install coil springs like a 1/2 ton truck or bronco from the 78/79 era.
With the 35" tires, it is possible to make the 44 and rear 60 survive. This is a very reasonable swap, you just have to have a plan on what you want to do.
Old May 29, 2009 | 05:22 PM
75F350's Avatar
75F350
You can keep the axle that you have, you will just have to modify it to accept coil springs and radius arms.
Old May 29, 2009 | 06:17 PM
rustee90-150
i dont have the axles yet so i should watch for a coil 44 or would i be better off to keep my independent front and just put on a lift kit?
Old May 30, 2009 | 12:26 AM
75F350's Avatar
75F350
If you start from scratch, then you might want to look for a coil sprung front end, and then just do a normal SAS.
Look at the many SAS options in this off road section to see how others have done this.
Justin Hickman
Mar 3, 2016 06:44 AM
dunny08
May 1, 2014 03:47 AM
Jaaaaaaackman
13
Apr 15, 2008 12:22 AM
bigbeise
1978 - 1996 Big Bronco
Sep 2, 2007 09:50 AM
89ranger
Exhaust Systems
Sep 14, 2003 07:40 PM
