diffs
i have a 89 full size bronco i want to upgrade to solid axle. would a d44 with leaf be ok up front and a d 60 out of an f250 be ok in back i duno the yars yet i will soon . is this gona be a ridiculous huge job ? i know its big and what am i gona need to get to do this as in parts mounts ect ? they both have 4.10 s i wana run 35's that gear gona work my engine is stock 302 with aod . thnxs shawn
Very good questions. Although, before advice or opinions can be shared, many should know what your intentions are.
You have asked about a D44 solid front axle with leaf springs and a D60 rear axle.
Well,,,,,,,,,,much depends upon which D44 front axle you select, and you might give up the idea of the rear D60.
Your Bronco has an axle that shares the same axle strength as the D60 rear. So other than weight capacity, the rear axle swap would be nothing more than,,,,,,,,,,,,,well there is not much of an advantage.
For the front, if you plan on running leaf springs, then you have your work cut out for you. This frame has no provisions for this, so you will have to be pretty sharp with a tape measure to verify "square".
Coils are pretty easy to keep.
Lets hear what you really want to do with this ride, and then you can recieve some feedback.
Making spring perches will not be that difficult but the frame widths are different so you will have to make spring perches and hangers for your bronco. This is much easier to install coil springs like a 1/2 ton truck or bronco from the 78/79 era.
With the 35" tires, it is possible to make the 44 and rear 60 survive. This is a very reasonable swap, you just have to have a plan on what you want to do.
Look at the many SAS options in this off road section to see how others have done this.
