Front axel seals
Front axel seals
Shop says my front inner axle seals inside pumkin may be leaking after they change knuckle joints, I can't really afford to have the seals replaced. They saying it's gona cost bout 600 more to change them. Do I need to worry bout this much or will it be OK for a while???? I don't go off road much at all,if I do it's on gravels roads and grass...will it cause any damage to inside pumkin or will it survive for a while????
Thanks , Justin
Thanks , Justin
What year truck? 4x4 or 2WD? Which seal are you referring to? Can you show from the link below?
2004 F250 Ball Joint Replacement
IDI-Charlie
09-29-2017 10:40 PM
4.9F-150
1999 to 2016 Super Duty
05-13-2009 03:50 PM
Deeta
06-09-2006 12:37 PM
