Oil
Old Feb 1, 2006 | 03:05 PM
bassproguy07's Avatar
bassproguy07
Oil
Every time i start my truck or let it idle, it smells like its burning oil. I just got the oil changed yesterday thinking it would fix the issue but nothing has changed. Anyone know why this might be happening?
Old Feb 1, 2006 | 03:27 PM
PLC7.3's Avatar
PLC7.3
Put some truck info in the signature area of the quick links above please.....
Have you checked the valve cover gaskets, they will leak directly on to the exhaust manifold.....try tightening them. The shop that did the oil change did they tighten the oil filter enough......1-1.5 turns more after seal contact.
Old Feb 1, 2006 | 03:43 PM
bassproguy07
Yah...its more like coming out of the exhaust pipe though, like if u rev it up a little itll do it and when its cold, it doesnt appear to be leaking at the valve covers though
Old Feb 1, 2006 | 03:46 PM
bilder12's Avatar
bilder12
has this been a persistent problem or something new? Also, are ya sure its motor oil and not a rich dose of fuel oil? With high mileage, you may be having a problem with valve guide seals leaking or a cracked piston ring or two. A little more info about the truck will help.
Old Feb 1, 2006 | 06:54 PM
Hamberger's Avatar
Hamberger
How much oil are you burning between oil changes? One liter or so between oil changes is normal.
Bordermen
20
Sep 28, 2019 03:48 PM
matowns21
19
Dec 30, 2011 09:27 AM
ItsAFord55
Aug 6, 2011 11:50 PM
itsjustagreat1
Mar 5, 2009 08:24 AM
Adam0331
40
Aug 31, 2008 09:09 AM
