three speed transmision
Old May 26, 2009 | 02:16 PM
dogbreath1000's Avatar
dogbreath1000
is there a 5 speed that will bolt to my 65 240??
Old May 26, 2009 | 10:01 PM
Bill W's Avatar
Bill W
I have read about guy's using a T5 trans. dont know how they fit, or if you need to modify anything.
Old May 27, 2009 | 02:00 PM
garbz2's Avatar
garbz2
Late Model small block pattern 300 302 351 ZF truck trans will bolt right up. Your 240 shares the same bell housing pattern.
You would need to add the hydraulic clutch master cylinder to the firewall and add a actuation rod.
There is a stock hydraulic clutch stamping in all 61 to 66 firewalls.
And you will need a four speed trans pan.
Simple upgrade.
Garbz
ANIMAL
Sep 4, 2002 03:31 PM
4_speed
Aug 25, 2002 11:20 AM
Yeti
May 17, 2002 04:16 PM
whiteboyslo
Nov 6, 2001 04:19 PM
slik
Oct 12, 2000 07:50 AM
