4 speed manual=??
Old Aug 24, 2002 | 12:24 AM
ANIMAL's Avatar
ANIMAL
4 speed manual=??
Old Sep 3, 2002 | 11:07 AM
rx3greenford's Avatar
rx3greenford
Post 4 speed manual=??
Ok, Ive got a 4 speed manual trans, first is a granny gear is this a c4 trans?? Also, if I dont have an inspection plate on the rear of the diff, does this mean its a 9 inch??
1978 f-150 4x4 351m
Old Sep 3, 2002 | 12:23 PM
Ohio Bill's Avatar
Ohio Bill
4 speed manual=??
>1978 f-150 4x4 351m
C4? Nope. C4's are three-speed automatics.
Your four speed is most likely a T19 or NP435 (if first gear
is synchronized. Can you get your trans into first gear when
the truck is rolling without grinding? If yes, first is
synchronized). The NP435 has an aluminum top cover.
If first is not synchronized, you most likely
have a T18 (or maybe a T98). Look at the following webpage
to ID your tranny.
http://www.novak-adapt.com/knowledge/transmission_gateway.htm
No rear cover MIGHT be a 9 inch. There's a trick for IDing
the 9 inch using a socket (a socket won't fit over all the
pumpkin bolts...I can't remember it exactly). Someone will
help out here... please.
Ohio Bill
Old Sep 3, 2002 | 02:53 PM
rx3greenford
4 speed manual=??
hmmm, must be an np435, 1st gear can only be used from a stop.. thanks for the imput....
Old Sep 3, 2002 | 03:08 PM
andym's Avatar
andym
4 speed manual=??
You have it backwards. If you can't get it in first unless you're stopped, it's not an NP435. You most likely have a T18.
The rear end is also most likely a 9". They didn't start making the 8.8's until years later.
Old Sep 3, 2002 | 09:26 PM
acogoff's Avatar
acogoff
4 speed manual=??
It's the bottom two pumpkin bolts that you can't get a socket on if it is a 9 inch.
1980 F-100
Old Sep 4, 2002 | 03:03 PM
lanero's Avatar
lanero
4 speed manual=??
>T18.
NP435's were definitely not synchronized. I have one and you can not shift into first w/o stopping.
I believe the T19's were synchronized.
Check out www.drivetrain.com. They have some good info on identifying transmissions.
Roger Lane
Old Sep 4, 2002 | 03:31 PM
brokebronco's Avatar
brokebronco
4 speed manual=??
The NP435 has an aluminum top cover and the t18 is cast. Both are unsyncronized.
BROKEBRONCO
84 Bronco 351HO/C-6/208/10.25 Rear/D44TTB Soon to have D60 Front/NP435 Wait, it does have the NP435 now!
86 F250 351HO/C6/10.25 Soon to have a front axle and the ZF tranny
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
