5 Volt Power Source
Old May 22, 2009 | 12:17 AM
7.3 Ex's Avatar
7.3 Ex
5 Volt Power Source
I know there is an electronics forum but I figured a PSD owner would know best. I'm wanting to install my new BD-Power Fuel Pressure Sender for my X-Monitor. It requires a 5 volt source. Can anyone tell me where I can tap into a constant key on 5 volt power source I can tap into either under the hood or dash? If one is not available, is there some sort of diode or power reducer I can use to cut down from 12 to 5 volts?
Thanks,
Matt
Old May 22, 2009 | 12:46 AM
Nick 99's Avatar
Nick 99
According to the website, you need a remote interface power supply.
http://www.dieselperformance.com/pro..._X-Monitor.pdf
Nick
Old May 22, 2009 | 01:03 AM
SpringerPop's Avatar
SpringerPop
Gauges usually need well-regulated voltage supplied, in this case +5 volts DC.
You have lots of 12-volt around, so why not step it down and regulate it at the same time?
Google "7805". There are three-pin regulator components available that are simplicity itself. An enclosure box, maybe a heatsink, some wire, solder, screws, etc, etc, and you're THERE!
12 volts in, 5 volts out. No muss, no fuss.
Pop
Old May 22, 2009 | 05:09 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Old May 22, 2009 | 10:13 AM
Tom S's Avatar
Tom S
Why not just use the 5v signal the pcm uses for the sensors as long as your wiring is done right I would see no issue.
Tom
xaviar
Sep 22, 2021 02:01 PM
pacnorwest
Jul 22, 2020 07:47 AM
RV_Tech
Nov 15, 2016 07:24 PM
mwells
May 20, 2014 10:28 PM
joezzz
Nov 29, 2012 10:09 PM
