gp shot?
Old May 21, 2009 | 05:18 PM
trugertha's Avatar
trugertha
gp shot?
my wts light comes on and stays on for 10-15 seconds then shut off.. and no clicking is a gp shot or the controller and help would be great..
Old May 21, 2009 | 07:56 PM
johnboggs21's Avatar
johnboggs21
My guess would be the controller, but i dont know for sure. Im certain someone else knows for sure.
Old May 22, 2009 | 03:27 PM
trugertha's Avatar
trugertha
ha now wts light stays on for 25 seconds then no clicking ...also truck has a hard time starting when cold, starts fine when hot. any info would be great as im making a pick a part run 2morrow. thanx
Old May 22, 2009 | 04:36 PM
sportsmobile1988's Avatar
sportsmobile1988
What glow plugs are in it and how old??? This might help:
https://www.ford-trucks.com/forums/8...plug-help.html
Old May 22, 2009 | 06:58 PM
trugertha's Avatar
trugertha
i have no idea whats in it i assume their as old as the truck maybe changed?
Old May 22, 2009 | 07:28 PM
johnboggs21
If their original they should be painted gray
Old May 22, 2009 | 07:35 PM
trugertha's Avatar
trugertha
their yellow haha
Old May 22, 2009 | 10:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There is a black wire from the controller under the relay that is usually under one of the mounting bolts.
Remove which ever bolt it is under and make sure the connection is good.
CAUTION, the battery terminal has battery voltage at all times, the ignition terminal has battery voltage when the key is in run position.
Use care working with metal tools around the relay unless the batteries are unhooked.
Big sparks if you ground it out.
Old May 23, 2009 | 10:50 AM
trugertha's Avatar
trugertha
thanx dave ill have a look..i got it to warm up with a gas soaked rag (dunno if this is safe or not used to start an old tractor that way haha) seemed to work fine after it was warm.
Old May 25, 2009 | 10:23 AM
trugertha's Avatar
trugertha
thanx for the info guys i did the old test light test and i have 6 dead plugs haha... off to the stealership. anyone have the torque specs for the gps?
Old May 26, 2009 | 10:28 AM
sportsmobile1988
Should be 12lbf-ft, at least that's what it says for my 88 7.3. Remember, Motorcraft Beru ONLY. I don't know about you but I would still test them out of the box just for piece of mind and future reference.
Old May 26, 2009 | 11:17 AM
trugertha's Avatar
trugertha
how do you test them not in the truck ?
Old May 26, 2009 | 12:33 PM
sportsmobile1988
Ohm meter. Test between the terminal and base. Should read .5 to 1.0ohm.
Old May 26, 2009 | 01:31 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You can still use a test light, it just takes a battery.
Just touch the threaded/hex part to the neg terminal of the battery, test light to positive and the GP terminal.
It might get a little warm though...
-Enjoy
fh : )_~
Old May 26, 2009 | 03:32 PM
trugertha's Avatar
trugertha
how many volts should be coming out of the relay? i have 11.5?
