Sponsored by: Real Truck
V10 Problem
Old May 21, 2009 | 05:30 PM
99f350sd's Avatar
99f350sd
So how bad is this miss buck etc? Do you think you are losing one cyl or more. How long does it last?
The stock plugs will go 100k so I'm sure it doesn't need them yet. At least 85k..You said it was already looked at do you think someone might have already looked at the plugs? You may have a crank sensor bad intermitten or a main connector doing the same thing. You might want to have it at idle and jerk on all the wires.
Dick
Old May 22, 2009 | 12:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Uh, did you ever actually check the REAL fuel pressure at the rail, especially under load during the bucking?
Bowhunter2001
Modular V10 (6.8l)
40
Nov 16, 2013 09:37 PM
racole
Michigan Chapter
Nov 23, 2004 11:22 PM
racole
Modular V10 (6.8l)
Jul 30, 2004 11:27 AM
todu5613
Modular V10 (6.8l)
May 19, 2003 07:58 AM
