Sponsored by: Real Truck
V10 Problem
Old May 20, 2009 | 08:27 PM
FX4 5.4's Avatar
FX4 5.4
V10 Problem
At my dad's shop tomorrow, a super duty v10 will be coming in. apparently it has been to 2 other shops in the area and no one is able to figure it out. i don't know the exact specs on it, but what i do know is that it is a 99-02 v10. the problem it has is that at no matter what speed it will begin to buck, but will smooth out soon after. we haven't test drove it, but the owner says it happens frequently. the other shops think it might be a fuel related issue like a pump. anyone else had this problem?
Old May 20, 2009 | 09:13 PM
Fordfanatic4life's Avatar
Fordfanatic4life
fuel filter or pump are def. good areas to start looking..
could be tons of things with that much info... electrical and so forth..
but start with small things first then go deeper..
i'd start by checking the fuel filter and fuel delivery system..
Old May 20, 2009 | 09:19 PM
99f350sd's Avatar
99f350sd
Of course a fuel pressure gauge will end the fuel question. Take it up a steep hill and get on it if it goes at first then starts to bog thats fuel. Gonna need lotsa fuel under those circumstances...Could be an intermitten coil.....Hard to say without driving it...
Dick
Old May 20, 2009 | 09:59 PM
Pinky Demon's Avatar
Pinky Demon
What do you mean by buck? I had a 97 Taurus that would sputter at low RPMS, (under 1300), and this was not any simple issue like a fuel filter or simple tune up maintenance. Let us know more.
Old May 20, 2009 | 10:03 PM
FX4 5.4's Avatar
FX4 5.4
i'll see tomorrow when he drops off the truck
Old May 20, 2009 | 10:56 PM
rudedogii's Avatar
rudedogii
Buck? My Bronco was bucking! I first thauht it was the trans was going out. You know like slipping out of gear.
But when it finally quit. I found the problem was in the ignition system!
I think a fuel system problem would be more like a sputter, than a Buck!
Old May 21, 2009 | 12:29 AM
JKBrad's Avatar
JKBrad
The MAF sensor can cause that problem too.
Old May 21, 2009 | 01:14 AM
Monsta's Avatar
Monsta
Sit. Stay.
I'm bettin' it's one or more bad COPs.
Subscribing.
Old May 21, 2009 | 06:44 AM
FX4 5.4's Avatar
FX4 5.4
oh i forgot to also mention that it won't pull any codes either
Old May 21, 2009 | 07:21 AM
Monster-4's Avatar
Monster-4
Subscribing.
I was thinking the same thing. I had two bad COPs after I changed plugs. My truck "bucked", etc usually on accleration and then smooth out while cruising. My scanner read the pending codes and showed misfires on two cylinders. I swapped in new COPs and problem gone.
Either way in this thread you have the basics covered, fuel, air, spark.
Old May 21, 2009 | 07:25 AM
Angrywasp's Avatar
Angrywasp
I second the fuel filter. I've seen a E250 that would drive fine at low speeds but when you got to 45 or above it would start to buck a lot. Turns out the fuel filter was shot. Our mech blew chunks of rust/crud out of the filter just by blowing in it.
Old May 21, 2009 | 07:28 AM
BareBones's Avatar
BareBones
Is it acceleration related, or cruising related?
Old May 21, 2009 | 07:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Here's an explanation of WHY you'll get no codes for a lot of things on the 2-valve V10. It's OBD-I.
https://www.ford-trucks.com/forums/5...t-come-on.html
Old May 21, 2009 | 08:12 AM
bubbasz1's Avatar
bubbasz1
You'll need a good scanner that will check for miss fires, miss fires generally won't pull codes.
Old May 21, 2009 | 05:18 PM
FX4 5.4's Avatar
FX4 5.4
ok here's an update. on the first test drive this morning, it didn't do anything. we put it on the four post an saw that the fuel filter was the original one the truck came with, which was rotted pretty bad (we replaced it). oh and by the way it is an early 03 with 58,000 on it. then on the 2nd test drive it did it. really bad buck and definitely a miss somewhere. we hooked it up to the snap on modis, but nothing came up. to make it worse for the owner too is that when he dropped it off last night he hit a deer and wrecked his bumper. he has only had the truck for a month and it has never not given him a problem. the guy took the truck because he needs it for the weekend but we'll be getting it back tuesday and we're gonna try to scope it to see which one is bad. we tried just about everything with the modis but just can't tell which it is. my guess is that the truck probably has never had a tune up either
