6.0 pyro
There are many root causes to cooling problems - some are:
- easy things like the radiator being clogged with dirt, grass, bugs, etc.
- the lower hose could collapse due to age and heat and restrict flow
- low coolant levels can be an issue (from leaks or flash boiling)
- there have been many cases of the water pump impellors coming loose
- use of the wrong coolant can cause solids to form and plug things
- could have a bad thermostat (although I think this is rare)
- bad things like leaking head gaskets or EGR cooler can cause overheating.
<table style="width: 247pt; border-collapse: collapse;" x:str="" border="0" cellpadding="0" cellspacing="0" width="329"><colgroup><col style="width: 88pt;" width="117"><col style="width: 51pt;" width="68"><col style="width: 66pt;" width="88"><col style="width: 42pt;" width="56"></colgroup><tbody><tr style="height: 12.75pt;" height="17"><td class="xl25" style="border: medium none rgb(212, 208, 200); width: 88pt; height: 12.75pt; background-color: transparent;" height="17" width="117">
</td><td class="xl26" style="border: medium none rgb(212, 208, 200); width: 51pt; background-color: transparent;" width="68">Normal</td><td class="xl27" style="border: medium none rgb(212, 208, 200); width: 66pt; background-color: transparent;" width="88">Severe Service</td><td class="xl26" style="border: medium none rgb(212, 208, 200); width: 42pt; background-color: transparent;" width="56">Alarm</td></tr><tr style="height: 117.75pt;" height="157"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 117.75pt; background-color: transparent;" height="157">Tranny Temp</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;">150 - 195</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;">195 - 200</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">220</td></tr><tr style="height: 27.75pt;" height="37"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 27.75pt; background-color: transparent;" height="37">Coolant Temp</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;">190 - 195</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;">195 - 210</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">215</td></tr><tr style="height: 36.75pt;" height="49"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 36.75pt; background-color: transparent;" height="49">Fuel Press</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'60 - 50">60 - 50</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'50 - 45">50 - 45</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">45</td></tr><tr style="height: 12.75pt;" height="17"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 12.75pt; background-color: transparent;" height="17">EGT - pre Turbo</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'650 - 1200">650 - 1200</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'1200 - 1250">1200 - 1250</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">1300</td></tr><tr style="height: 12.75pt;" height="17"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 12.75pt; background-color: transparent;" height="17">EGT - post Turbo</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">700</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">900</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">1000</td></tr><tr style="height: 12.75pt;" height="17"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 12.75pt; background-color: transparent;" height="17">Boost</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'0 - 26">0 - 26</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'27 - 28">27 - 28</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">28</td></tr><tr style="height: 18.75pt;" height="25"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 18.75pt; background-color: transparent;" height="25">Oil Temp</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'200 - 220">200 - 220</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'220 - 235">220 - 235</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">235</td></tr><tr style="height: 18.75pt;" height="25"><td class="xl29" style="border: medium none rgb(212, 208, 200); height: 18.75pt; background-color: yellow;" height="25">Oil Press</td><td class="xl30" style="border: medium none rgb(212, 208, 200); background-color: yellow;" x:num="">12</td><td class="xl31" style="border: medium none rgb(212, 208, 200); background-color: yellow;">na</td><td class="xl31" style="border: medium none rgb(212, 208, 200); background-color: yellow;" x:num="">7</td></tr><tr style="height: 12.75pt;" height="17"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 12.75pt; background-color: transparent;" height="17">HPOP Discharge Press</td><td class="xl28" style="border: medium none rgb(212, 208, 200); background-color: transparent;">
</td></tr><tr style="height: 12.75pt;" height="17"><td class="xl24" style="border: medium none rgb(212, 208, 200); height: 12.75pt; background-color: transparent;" height="17">Coolant system Press</td><td class="xl28" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:str="'10-12">10-12</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;">na</td><td class="xl25" style="border: medium none rgb(212, 208, 200); background-color: transparent;" x:num="">16</td></tr></tbody></table>
