trans coolant lines
Old May 18, 2009 | 05:13 PM
swordman's Avatar
swordman
Question trans coolant lines
hi, can someone tell me which trans coolant line is in and which is out on a C6 trans. i need to know which way the fluid flows so i can hook up a trans cooler on my 1978 f150 4X4? thanks for all the answers ahead of time.
Old May 18, 2009 | 06:34 PM
75F350's Avatar
75F350
C3, C4, C5, C6, and E40D have return lines at the rear of the transmission.
Old May 19, 2009 | 07:00 PM
JimsRebel's Avatar
JimsRebel
Where is the best place to install one of those inline magnetic filters.
1986 F150 300 c-6
Old May 20, 2009 | 12:49 AM
75F350's Avatar
75F350
A magnet in the pan is probably best. An in line magnetic filter can restrict flow. If you are great with maintenance then you probably do not need this redundant device.
Should you desire to install one, universal kits come with clamps, so if clamps are used, these filters have to go on the return side if the trans has any miles on it.
For new systems, these style filters are suggested to be installed before the cooler to prevent the cooler from becoming contaminated.
Manufacturers instructions discuss this in detail...........
Old May 20, 2009 | 10:55 AM
JimsRebel's Avatar
JimsRebel
Originally Posted by 75F350
A magnet in the pan is probably best. An in line magnetic filter can restrict flow. .........
I think I will just go with the magnet in the pan.<O</O
<O</O
Is it already there, does it come with a magnet stock or is it something that gets added later on? Where in the pan is the best place to put it, near the oil return line?<O</O
<O</O
I will be dropping the pan to change the fluid and also draining the torque converter. I was planning on not changing out the filter if it looks nice and clean inside. I have read that the filter is really just a screen and does do much in the big picture. If I don’t R and R the filter there is less chance that I might mess up something. This will be my first time changing the fluid in an Automatic trans. I have not got a pan gasket yet, lots of choices on what they are made out of.<O</O
<O</O
Thanks for the info.<O</O
<O</O
Jim<O</O
finitetime
Feb 10, 2025 05:07 PM
Leichardti
Feb 15, 2013 04:42 PM
timellis
Mar 24, 2012 07:39 AM
DPhillips
Feb 23, 2007 08:58 AM
dfbi
Jan 5, 2006 08:13 AM
