FMX to C4
Old Feb 22, 2007 | 05:29 PM
DPhillips's Avatar
DPhillips
FMX to C4
I'm replacing my FMX with a built C4. There are 2 coolant fittings on the trans that will run to the cooler, one at the front of the trans and one at the rear. Which is the pressure line from the pump? I'm running to a B&M plate type cooler. I want to make sure the lines are connected properly. Any advice?
Old Feb 23, 2007 | 06:04 AM
stuart1's Avatar
stuart1
The front line is pressure, rear is return.
Why are you replacing an FMX with a C4?
Old Feb 23, 2007 | 06:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your profile says F100, but a 65 F100 would not have an FMX transmission. It should have a Cruise-O-Matic (MX) whether you have a 352 or a six cylinder, and that's a better trans than a C4. You won't see a C-4 in the F series till 1967, and a FMX wasn't even available till 1969, as it was developed for the new 351 Windsor engines, and used in cars only.
No FMX's were used in F Series trucks till 1973, and then only on the 6 cylinders, and a few 302's.
Old Feb 23, 2007 | 08:58 AM
DPhillips's Avatar
DPhillips
The engine in the truck is a 289 from a Mustang. I'm going with a C4 mostly for price and performance. A C6 sucks up too much power and an AOD is too expensive.
79FordBlake
Jun 10, 2010 05:13 PM
OregonGuy1978
Aug 20, 2007 07:07 AM
46fordtruck
All Things Towing
Mar 10, 2005 12:11 AM
minishtr
Feb 27, 2004 06:54 AM
