What's a C-4?
Old May 18, 2009 | 04:45 PM
Thudpucker's Avatar
Thudpucker
What's a C-4?
I have a line on a swap to a 300 six and the guy has a C-4 available. I want an auto for my convenience.
Is a C-4 a good reliable maint bet. Similar to a C-6 but what's the difference?
Old May 18, 2009 | 08:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's the same design as the C6, just scaled down. Think of it as a smaller version of the C6.
Old May 18, 2009 | 08:33 PM
Thudpucker's Avatar
Thudpucker
So it'd be safe to use behind a 300 six pulling a bass boat trailer occasionally. And other wise it'd be just fine. No different than a C-6 behind a small block V-8?
I can see some expenses coming up. If I dont have a Donor 300/C-4 I'm gonna have to come up with some linkages, a Torque Converter and a Auto TC plate.
The Steering column with the Shift indicator. What else?
Thanks.
Old May 18, 2009 | 08:44 PM
Old Brown Truck's Avatar
Old Brown Truck
C4-s were stock transmissions behind 300-6 and 302's in 60-70 era pickup trucks. Also very common in Ford cars. C4s can be built to take a beating as many Mustangs have them. The small block C6 I had supposedly came out of an Econoline Van. You may find an easier time with drivelines and what-not going with the C4
Old May 18, 2009 | 11:48 PM
Ford_Six's Avatar
Ford_Six
I thought it had two bands as opposed to one in the C6?
At any rate, I had one in my 69 F250 behind a 300-6, and it was decent. The only two problems were a torque converter noise that sounded like bad piston slap, and the nut on the yoke came loose. I put some RTV in the space behind the shaft splines in the yoke, and cranked the nut back down, no more leak and no more jumping speedometer.
BlackLabel78
Jun 1, 2009 12:30 AM
dtherren
Apr 1, 2006 08:06 PM
ford351w
Apr 30, 2002 12:55 PM
Jermafenser
Feb 6, 2002 01:45 AM
TC73Fleetside400C4
Sep 6, 2001 05:17 PM
