Bronco II Ford Bronco II
Engine Swap:
Old May 17, 2009 | 10:55 AM
blockheadbob's Avatar
blockheadbob
Engine Swap:
I want to get rid of all the electronic junk in a Bronco ll. Is there any engine from the points era that I can swap in that is compatable withe the 5 speed 4x4, besides a V8?
Thanks in advance,
Bob
Old May 17, 2009 | 07:24 PM
rebocardo's Avatar
rebocardo
Swap in a 2.8L from a 1984/1985, ditch the carb for a Holley and ditch the TFI for a duraspark set up.
Old May 18, 2009 | 08:00 AM
kernel-panic's Avatar
kernel-panic
Or save the time and do a tri-power setup (you'll need to change the fuel pump out for low-pressure...) and convert the ignition to Duraspark/HEI/TFI (gofastforless.com homebrew). You just have to find the right 2-bbl carbs and fab up the upper intake adapter. I honestly do not understand why you want to get rid of your 2.9 unless you plan on doing a 4.0 or V8 swap, but to each their own.
Truckin23
1947 and Older Ford Trucks
Aug 24, 2013 01:21 PM
Mr. Bob
Oct 13, 2006 09:30 PM
Bob's 1984
Engine Swaps
Jan 8, 2005 08:31 PM
Bob Chan
Jun 10, 2004 12:25 PM
