49 8BA into a 1942 1 1/2 ton Flatbed
shouldn't have any major issues as long as you also have the tranny for the 8BA. the 59 engine has the bellhousing cast into the block as opposed to 8BA. you maybe able to find an adapter to fit your original tranny to the 8BA engine. all mounts should be the same, upper radiator hoses will be a little different as the 59 heads have water ports in the middle and 8BA at the front of the head. overall it should a fairly simple swap.
ovrhtlksoil@msn.com if you want photos or have other questions.
Tim
Thanks Tim
I will email you I'm waiting for my bell housing to arrive I got one on EBay
http://www.ebay.com/itm/1949-50-51-52-53-FLATHEAD-FORD-TRUCK-ADAPTER-PLATE-LATE-TO-EARLY-CONVERSION-/350851580372?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWNX%3AIT&nma=true&si=FVEh%252Fq2%252Fzm8h2yoFVR4ALNJKpV0%253D&orig_cvip=true&rt=nc .
Today I call Flathead Jack in Walnut Creek , CA about an 50 min. from me and he recommended
Al Hubbard Machine Shop in Hayward , CA 30 min. away for all my machining hot tank 65 and magnaflux block 20 not bad .
I'll be in Sacramento next week so I'll pick up parts at Sacramento Vintage Ford and save on shipping .
Bob
Bob
farmall_7
15
05-08-2016 06:12 PM
cuellar23
06-02-2013 02:01 AM
