Cruise control not working
Old May 16, 2009 | 11:50 PM
95_Dually's Avatar
95_Dually
I have a 95 F350 cc dually. The cruise control just stopped working. It has been working just fine. I changed the cruise control switch on the master cylinder. It is the only one listed by napa. Thank you for your assistance.
Old May 17, 2009 | 02:06 AM
kawa's Avatar
kawa
Check your Tail and Brake lights including the "Third" brake light. If one (1) of them is B/O the cruise won't work. Also check the fuse.
Rog
Old May 17, 2009 | 02:59 AM
95_Dually's Avatar
95_Dually
What does B/O mean?
Old May 17, 2009 | 04:56 AM
Towmanjbo's Avatar
Towmanjbo
burned out
Old May 17, 2009 | 11:05 AM
95_Dually's Avatar
95_Dually
Oh. Thank you. LOL
Old May 18, 2009 | 12:13 AM
95_Dually's Avatar
95_Dually
I checked all of the brake lights, all of them are working properly. I checked all of the fuses with a multimeter and all of them are good. What else do you recommend? All suggestions are appreciated.
Old May 18, 2009 | 01:37 AM
kawa's Avatar
kawa
The only thing that comes to mind are the switches that activate the system as well as the switch that sets it.
You might also check to make sure that your brake lights are not staying on.
Rog
Old May 18, 2009 | 02:14 AM
95_Dually's Avatar
95_Dually
The brake lights do not stay on. I will check the switches on the steering wheel tomorrow. Thank you.
Old May 18, 2009 | 08:18 AM
bd350's Avatar
bd350
I had the same problem and it turned out to be the speed sensor in the differential.
Old May 18, 2009 | 11:15 AM
nelstone74's Avatar
nelstone74
Have you noticed you speedo bounce around at all? I think that is one sign of the sensor in the diff giving up
Old May 18, 2009 | 04:04 PM
95_Dually's Avatar
95_Dually
The speedometer doesn't bounce, it is very steady. Please keep trying, thank you.
Old May 19, 2009 | 05:58 AM
bd350's Avatar
bd350
Yeah, it did... It's a pretty easy fix if the sensor comes out in one piece (mine didn't), it's located in the top of the third member. I went to Autozone first and they gave me the wrong part, then went to NAPA, they showed me the same part Autozone sold me, I finally ended up at the Ford dealer and they new exactly what part I was talking about and it wasn't any more money then the wrong part at the other places!
HJ
skyhigh
23
Apr 17, 2013 08:13 AM
95_Dually
20
Dec 12, 2010 06:43 AM
cfor
Nov 18, 2010 09:58 AM
bugeyed
Feb 25, 2003 05:29 PM
