Cruise control not working
Old Apr 10, 2013 | 01:04 PM
skyhigh's Avatar
skyhigh
My cruise control is not working at all !!
Any insight? I sure hope this is an easy fix.
1999 F-350 XLT Crew Cab, 7.3 6-speed dually
Thanks,
Robert
Old Apr 10, 2013 | 02:33 PM
th67ss's Avatar
th67ss
Does your horn work? If not it may be your clock spring. When my cruse went out that was my problem, the clock spring
Old Apr 10, 2013 | 02:47 PM
HH60FE's Avatar
HH60FE
Check your third brake light
Old Apr 10, 2013 | 02:55 PM
SpringerPop's Avatar
SpringerPop
Good call, Matt!
However, we need to keep in mind that the O/P's truck is a six-oh!, according to his profile.
Skyhigh, it might be a good thing to fill our your signature file, and let folks know to what vehicle profile you are referring.
Pop
Old Apr 10, 2013 | 03:18 PM
skyhigh's Avatar
skyhigh
Originally Posted by SpringerPop
Good call, Matt!
Pop
I have a 1999 f-350 dually 6 speed 7.3 XLT crewcab
Old Apr 10, 2013 | 03:25 PM
Baatzy's Avatar
Baatzy
Is your ABS light on? If so it could be the Vehicle Speed Sensor on the rear axle. I was told this as a possible fix to mine, but I also don't have a functioning cruise control. However replacing the VSS took care of the ABS light. I'll be watching this to see if a solution is found.
01 F250 7.3 6 speed 206k
Baatzy
Old Apr 10, 2013 | 03:38 PM
skyhigh's Avatar
skyhigh
My horn works.
What & where is a "clock spring"
Old Apr 10, 2013 | 03:41 PM
skyhigh's Avatar
skyhigh
Third brake is not staying on with no brake applied.
I'm by myself right now & can't tell if it comes on when applied, will check that later
Old Apr 10, 2013 | 03:42 PM
ronjon95's Avatar
ronjon95
Since you have a 6 speed there is the clutch switch on the pedal. Look under the dash and you will see it. This was my problem a few years back. I got a new one from Advanced Auto.
Old Apr 10, 2013 | 04:38 PM
HKusp's Avatar
HKusp
The clock spring is in the steering column. Images here
If it turns out not to be that, it could be a few othr things as well. There is a wire off the master cylinder that had a recall. Or it could be the cruise control module itself. Thre is an old thread over in the SD forum here that goes through if it is not the clock spring. They never get to the bottom of this guys particular issue, but he has some good info in the thread.
Old Apr 10, 2013 | 06:43 PM
Boss73's Avatar
Boss73
I agree with ronjon, when mine wasn't working I replaced the clutch pedal position switch and that fixed the problem. It is located on the clutch pedal rod going thru the firewall. I purchased mine from rockauto, but don't remember how much it was. You can search the switch on here and it will come up with instructions on how to locate and fix it.
Old Apr 10, 2013 | 07:24 PM
Baatzy's Avatar
Baatzy
Are there symptoms to go with each potential problem? My horn works fine, so I don't think its the clock spring. Is there something that would tell us its the clutch position switch or possibly the wire on the master cylinder? Does anybody know of a way to test the cruise control module?
Thanks, Baatzy
Old Apr 10, 2013 | 10:34 PM
kawcrasher's Avatar
kawcrasher
Check the pressure switch on the master cylinder. If it's leaking it's probably bad. It is just a NC pressure switch, so it's easy to check.
I am not sure how the clutch switch is set up. Just check to see if it changes states when the pedal is pushed.
Old Apr 11, 2013 | 07:54 AM
thomabb's Avatar
thomabb
If you have had the recall done on the truck for the cruse control, there is a fuse in the wire coming off the master cylinder. See if it is popped. If it is, it saved you from a potentially nasty failure/fire.
Old Apr 11, 2013 | 02:12 PM
clem1226's Avatar
clem1226
I dont have a six speed but.....if the clutch disengaged switch was bad would you be able to crank the motor without engaging the clutch?
I have never driven a six speed superduty so I have not idea what the safety interlocks are.
