4R70W?????????????
Old Jul 24, 2002 | 02:41 AM
charlez's Avatar
charlez
4R70W?????????????
>Can anybody tell me where I can get a core, or a working
>4R70W for a 302 engine? I need to put an overdrive in to
>makeup for the 3.70's I want to put in the rear, and I've
>read enough to confirm that this was the best automatic that
>Ford has made yet. The only problem is that I can't find a
>core at a decent price to rebuild. Thanks for the replies.
>TK
>'77 F100, 302 (the aftermarket Prodigy), C4
>Cadet Second Lieutenant John F. Daly III
>South Carolina Corps of Cadets, The Citadel
>The TorqueKing
I don't think you can get a 4R70W to bolt up to a 5.0/5.8. They only bolt up to the modular engines (4.6/5.4). The AODE will bolt up to the 5.0. The only difference between the two is that the 4R70W has a different gear set and a different output shaft. If you are planning on putting either of these transmissions in your '77 F100 they won't work. Both of these are computer controlled transmissions.
It sounds like you need an AOD. It will bolt up to the 5.0 and has no electonics in it. All it needs is the TV linkage hooked up.
Old Jul 24, 2002 | 03:14 AM
TorqueKing's Avatar
TorqueKing
4R70W?????????????
I realize that, but Bauman engineering makes kits for using these on non-computer controlled engines. They said that a few of the did come on Windsor V8's, but I have no idea which ones they came on. If the output shaft is different, I should be looking at AOD-E's, and then I'll just get the 4R70W gearset, so I can have that 2.79 first gear, which should fit right in from what I've read. Does this make sense? I guess an AOD would be fine, as long as it had that 2" overdrive band, I'm not interested in tearing up OD bands, that's why I was looking into the AOD-E's to beging with. Thanks for the help, I'm trying to get this together so I can finally swap my rear end ratio for something in the range of 3.70 without losing my highway cruise speed. TK
Old Jul 25, 2002 | 06:31 PM
Ryan50hrl's Avatar
Ryan50hrl
4R70W?????????????
I've got a 4r70w in my 95 f-150 with the 5.0. I'm actually pretty impressed with this tranny. I put a beating on it and its held up well. knock on wood.
Ryan
Old Jul 26, 2002 | 01:06 PM
superrangerman2002's Avatar
superrangerman2002
4R70W?????????????
Mark Kovalsky
Dec 20, 2015 10:28 PM
aaronjohnston
Aug 27, 2010 06:16 AM
palace55
Apr 20, 2010 06:48 PM
karenj
1997 - 2003 F150
Nov 12, 2003 10:11 AM
66stangfb
Nov 26, 2002 10:01 AM
