leaking gear oil...HELP
Old Jul 25, 2002 | 04:36 PM
blueoval79's Avatar
blueoval79
I'm leaking gear oil from the front axle just inside the right front tire. It's sprayed all over the inside passenger tire. Is it a seal or something major. It's a Dana 44.
Old Jul 26, 2002 | 01:06 PM
superrangerman2002's Avatar
superrangerman2002
>Dana 44.
Seal is prolly bad, its not too hard to work with if you got the right tools to get the 4x4 hub off. If I were you I'd do the wheel bearings, needle bearings and seals on both sides, it will save you alot of headaches later.
super
Old Jul 26, 2002 | 01:16 PM
brokebronco's Avatar
brokebronco
Square Grouper
Oct 6, 2016 05:53 PM
'02strokerpilot
Feb 14, 2016 05:36 AM
OldWoodsDiesel
Oct 26, 2013 09:31 AM
jleal_21
May 4, 2012 09:26 PM
joe_r_dog
Oct 12, 2011 10:34 PM
