fueling problem
Old May 13, 2009 | 12:30 PM
Izzy351's Avatar
Izzy351
The stream increases quite a bit just by turning the pump on with the return working (even in mine with the extra return via the CCK). If there's no return, it'll build up a butt load of pressure and shoot out of the fuel drain like a fire hose. Of course, you could just keep it closed, let it build pressure, then open it... Put your goggles on.
I know this because when I pumped out my tank, I used the fuel drain with a hose on it and kept cycling the key until the tank was empty (only had a couple gallons in it).
Old May 13, 2009 | 12:32 PM
Izzy351's Avatar
Izzy351
Can those of you with Reg Returns shut the return completely off and see what happens with the fuel drain open?? That would solve the mystery...
Jerrywgroah
Large Truck
Apr 10, 2015 10:51 AM
BobbySmith
34
Feb 13, 2009 05:52 PM
mdpitt
1997 - 2003 F150
Sep 12, 2007 08:33 PM
larrydean
1983 - 2012 Ranger & B-Series
May 19, 2003 08:51 AM
