steering sector
May 11, 2009 | 10:38 AM
steering sector
How many steel ***** in a manual steering sector on a 65 F100-250? Sector had 50 rebuild kit has 60.
Thank You!
May 11, 2009 | 06:37 PM
think there are the 60 but not totaly for sure
May 12, 2009 | 02:16 AM
Quote:
Originally Posted by
Blackwaterforge
Thank You!
2)
C1AZ3576B .. Sector Shaft Bearing / This is a
caged bearing.
How many steel ball bearings are in each cage, the parts catalog doesn't say.
KINSEL L/M in Beaumont TX has THREE. You could call them and ask: 800-816-2894.
Fits: 1965/72 F100/250
2WD / 1967/72 F350 / 1961/64 Galaxie / 1963/65 Falcon/Fairlane / 1965/70 Mustang.
1964 and earlier F100/250's are not the same part, neither is 1961/66 F350's.
May 12, 2009 | 07:13 AM
Thank You!
Thank You for your replies. These are the ***** that go into the reciprocating block. There are 50 from the factory. The rebuild kit has 60. Are the extra ***** for wear in the worm shaft or dose this kit fit several models?
Thank You!
May 12, 2009 | 12:01 PM
Blackwaterforge
These are the ***** that go into the reciprocating block OF THE INPUT shaft, not the sector shaft. .
Are the extra ***** for wear in the worm shaft or dose this kit fit several models? Thank You!
Dueling parts catalog refs.
The illustration says
50 ...
1)
B8A3647B .. Steering
Input Worm & Shaft Ball Bearing Kit, consists of
60 ball bearings.
The deal is...that some 1965's used 50, while some 1965's used 60, which were also used thru 1972.
The original 1965 steering gearbox was C5TZ3504A.....within a few months, Ford replaced C5TZ3504A with C5TZ3504D.
May 12, 2009 | 12:04 PM
Thanks ND!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for all your help ND!
May 12, 2009 | 12:07 PM
Blackwaterforge
You don't have to bother KINSEL L/M for the sector bearings, but they do have that clutch adjustment rod you asked abou in another thread.
Hmmm...after reading the other thread, I see you want something else...read my response there...in a few minutes.
dlb.motorman
Feb 4, 2015 08:48 AM
thekingofcows
Offroad & 4x4
16
Mar 8, 2012 06:20 PM
Moose2
Mar 29, 2011 07:45 AM
52 F3
Nov 30, 2008 09:09 AM
D-f250
Sep 8, 2006 04:52 PM
