Offroad & 4x4
Sector Shaft Interchange
Old Mar 6, 2012 | 11:19 PM
thekingofcows's Avatar
thekingofcows
The sector shaft on my 79 Ford, won't seal because the sector shaft is kind of pitted where the seal rides. So I was wondering if there are any tricks y'all have for fixing a leaking sector shaft, or if a sector shaft from a newer power steering box will fit.
Old Mar 7, 2012 | 06:25 AM
hav24wheel's Avatar
hav24wheel
Newer sector will not fit.
But a seal kit from a older box will fit. Like a 76 I think was what I used. Anyways the lower seal kit came with two pressure seals instead of a pressure and a dust.
Old Mar 7, 2012 | 12:07 PM
thekingofcows
I have the seal kit, but my shaft is pitted, even with new seals it leaks.
Old Mar 7, 2012 | 05:29 PM
alpha/omega's Avatar
alpha/omega
Its possible you could have your shaft turned or polished to remove the pits and then source a seal to fit but thats a shot in the dark.
It would be easier, and probably cheaper, to find a box in better condition.
Old Mar 7, 2012 | 05:35 PM
thekingofcows
I have a lathe and thought about setting up between centers and refinishing it, but I wasn't sure how I was going to find a seal with the right dimensions.
But part of me thinks, if I used a stock seal and polished the bearing surface it might make a leak free seal, but that still kind of a shot in the dark.
It isn't leaking really bad, but I just don't like leaks of any nature. I Have heard over te years that if you put it in the top and it doesn't come out the bottom, then it's not a ford but Im still skeptical of that.
Old Mar 7, 2012 | 06:49 PM
hav24wheel's Avatar
hav24wheel
349060 gates part #. Lower seal kit with two pressure seals. I had the same dam problem, I fixed it with a ki for a older model that had two pressure seals instead of one and a dust seal.
Here is the kit
Here is the kit made for yours.
Notice they are in fact different. Notice the top kit has two of the same seals.... Notice that they will ride in different spots on your sector shaft and seal twice as good as one seal.
Notice this is the second time I'm telling you this. I have done it. It works. I don't remember the order of seals vs spacers and all that, but I did use some spacers out of my box and some that came in the kit.
Old Mar 7, 2012 | 06:58 PM
thekingofcows
Ok thanks I will try that, however my kit came with two pressure seals. But no spacers that I can think of.
Old Mar 7, 2012 | 07:07 PM
hav24wheel's Avatar
hav24wheel
Do the seals look identical in ur kit??
Old Mar 7, 2012 | 07:31 PM
thekingofcows
They are identical.
Old Mar 7, 2012 | 07:57 PM
hav24wheel's Avatar
hav24wheel
Well jam them in there than. U should be good to go. If u have spacers u in ur box with the seals always can install in a different order to keep the seal in a diff spot on the sector
Old Mar 7, 2012 | 09:20 PM
thekingofcows
I will try it but every available is worn.
Old Mar 7, 2012 | 11:11 PM
73 ford guy's Avatar
73 ford guy
I've "heard" that ford never put bearings in the bottom section of steering boxes as they would sell a brazillion amout of seals. Company called Redhead steering takes your box and can machine and press a bearing in. I guess they oval out.
I had issues with getting my seals to hold after hydro assist. Put in new ones and no luck. Then I said screw it and took it to a shop and they did it. Fixed it right up. I think the trick was the seals looked like the were coated in Vaseline.
Can't see why the shaft couldn't be welded in pitted areas then smoothed out as well. Talk to redhead steering I wouldn't be surprised if they regularly do this
Steering Gear Remanufacturing | Manual & Power Steering Gear Box
Old Mar 7, 2012 | 11:18 PM
73 ford guy
Looking into it looks like instead of welding they do flame spraying? Never heard of it. Kinda checked it out. Blasts steel onto surfaces? Too tired to look into it more..
Old Mar 8, 2012 | 02:43 AM
alpha/omega
NOTICE, Dave is a major tool. :flip:
Nice to know about the older seal kit. Goes to show even BA MFers have room to learn something from time to time.
73, Ive seen some boxes that have bearings. Definitely the way to go if you have a lathe or mill handy. I have the timken number at home for the bearing.
That flame spraying deal is used quite often in body work. Ive never seen it done but sounds like a cool SiFi-esque deal. Not sure how well that would work on a sector shaft or similar part though.
Old Mar 8, 2012 | 06:24 AM
hav24wheel's Avatar
hav24wheel
Tool or not, My steering box didn't leak, even with the crack in the sector shaft. :flipoff:
