What is the length of the clutch rod that connects the Z bar and the clutch pedal? PO scobhobbled the one in the truck(65 F-250) and it looks to long.
Thank You!
Thank You!
Originally the clutch rod came in two separate parts.
In 1970, Ford came out with a rod kit that includes both.
The two parts:
The clutch rod is 3 29/32" long.
The clutch rod extension is 2 27/32" long.
This extension is pointed (someone here said it looks like a crayon = yup!) and slides over the threads of the rod and is double nutted.
DOTZ7521C .. Clutch Adjustment Rod Kit / Obsolete
Fits: 1965/66 F100/250 2WD / 1967/79 F100/350.
KINSEL L/M in Beaumont TX has ONE: 800-816-2894.
BOB ALLEN FORD in Overland Park KS has ONE: 800-676-0675.
This rod kit is getting hard to find, several months ago there were at least 8 more.
These two dealers are the last ones that have any.
Thank You!
Uh...lemme try this again...dumb me missed the clutch pedal reference.
C5TZ7521B .. Rod, Clutch Pedal Bellcrank to Equalizer (Z) Bar / 18 7/8" long / 3/8" diameter rod / Ends are bent at right angles / Obsolete
Fits: 1965/66 F100/250 2WD.
I found exactly one...P/M sent.
2) COAZ7526B .. Nylon Bushing-Clutch Pedal Rod / Obsolete
What happens to the rod: The bushings wear down, fall apart. Then....the right angle ends begin to crack...eventually...they snap off.
