cam sensor problem
Old May 10, 2009 | 12:00 PM
dbf74's Avatar
dbf74
cam sensor problem
Have a 96 F350, and have put 3 cam sensors in it in less than 1200 miles. I ckecked out the harness and plug at the sensor and they are fine. Any ideas on what could be causing this? Also breaks up if you get on it hard between 2100 and 2700 rpm. It smellslike unburned fuel all the time but doesn't smoke.
Old May 11, 2009 | 06:20 AM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE
That can be normal in some extreme cases. They can be bad right out of the box. At least they are much cheaper now...even at the dealer.
You need to get it on a good scanner just to be sure it's a CPS.
Look at the end of the CPS for damage. If your cam is walking back and forth excessively it may hit the CPS. Might need to be shimmed. Even if it doesn't hit it may cause an erratic signal....
Old May 11, 2009 | 06:56 AM
DRRXR's Avatar
DRRXR
Originally Posted by Cuda_jim
Welcome to FTE
Cuda
I keep reading about shimming the CPS. Whats the process?
Rocky
Old May 11, 2009 | 06:19 PM
dbf74's Avatar
dbf74
thanks
Thanks for the info, my mechanic said the same thing, and i wanted to back it up. I guess I'll see if it happens again.
Old May 11, 2009 | 06:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by DRRXR
Cuda
Rocky
I dont know the process but here is the kit
Camshaft Position Sensor (CPS) shim kit
  • (International) 1826583C91
got2befast
Sep 14, 2010 11:14 PM
dirtworker
Mar 26, 2008 01:35 PM
tapple
Apr 3, 2005 09:39 PM
vtcart
Sep 24, 2004 06:26 PM
Spud
Jul 21, 2003 11:48 PM
