cam sensor and lpop
Sep 5, 2010 | 04:33 PM
cam sensor and lpop
Where is the cam sensor on 2006 6.0 located? Does anyone have instructions on disassembly of the lpop and reassembly? thnx
Sep 5, 2010 | 06:28 PM
Before we go to far here, why? Cam sensors are not an issue with the 6.0L and what happened to your low oil pump?
Sep 5, 2010 | 06:33 PM
had a brand new cam sensor given to me so was going to replace just cause if it wasnt to hard to get to. Now the lpop was going to change it out just for insurance reasons, my hpop went out so since I put a new one on figured I would go ahead and put A new lpop on also since the truck does have 198000 miles on it.
Sep 5, 2010 | 06:34 PM
if your chasing it for a cam sensor code odds are thats not the issue.
to remove the lowpressure pump. remove the shroud,stator,fan, and balancer. remove the cover that is behind the balancer and theres the gearset.
Sep 5, 2010 | 08:27 PM
thanks do you know the torque
Sep 6, 2010 | 10:58 AM
also does any one have picture or can tell me where the cam sensor is located?
Sep 6, 2010 | 10:59 AM
cmp is behind the power steering pump.
Sep 6, 2010 | 11:30 AM
Do I have to pull the powersteering pump to get to it?
Sep 6, 2010 | 11:39 AM
I dont have to. look up from under the truck its the 2 wire connector and its the only sensor on that side that far down.
Sep 6, 2010 | 04:03 PM
Ok thanks. Also cheezit is it true that you have to put new dampner bolts in? Do you know what they are to be torqued at?
Sep 6, 2010 | 05:31 PM
you should replace the dampner bolts.
I dont even attempt to remember torque specs except for a few items. there are so many its easy to confuse them sometimes.
Sep 14, 2010 | 10:44 PM
Does anybody know the torque specs for the dampner bolys and lpop cover bolts?????
Sep 14, 2010 | 10:50 PM
Sep 14, 2010 | 11:14 PM
FUJINAMI1293
May 25, 2013 01:41 PM
yblegal
Mar 2, 2012 01:08 PM
glovemeister
Sep 16, 2011 06:20 AM
Sonny Dee
Aug 13, 2009 11:46 AM
1999 ,
38 ,
60 ,
cam ,
change ,
code ,
del ,
diesel ,
f250 ,
ford ,
location ,
lpop ,
pics ,
picture ,
powerstroke ,
replacement ,
sensor ,
sensores ,
winstar
