Cam Sensor
Old Jul 20, 2003 | 01:38 PM
Spud's Avatar
Spud
Unhappy Cam Sensor
Is there a issue with Cam sensors on F-250 Super Duty going out? have 189,000 miles so far Had to change Abs speed sensor recently an was told the cam sensor was next??? Thanks Ted in Austin
Old Jul 20, 2003 | 02:05 PM
Quadzilla's Avatar
Quadzilla
Cam Sensor
If you've put all 189,000 miles on yourself, and haven't replaced the cam position sensor yet, you've done well. They typically go out around 100,000 miles. There was a running change in the design of the cps during the '96 model year, so the person behind the counter at the International dealer might want to know whether yours takes the new one or the old one. The difference between the two is the material the electrical contacts are made of, so either way, get the new one. They're about $85 at International, or you can get the exact same part, in the exact same bag from your Ford dealer for twice that.
Old Jul 20, 2003 | 02:27 PM
Spud's Avatar
Spud
Cam Sensor
Thanks Quadzilla....
Old Jul 20, 2003 | 03:00 PM
rvfiver's Avatar
rvfiver
Cam Sensor
They are notorious for going out. Could happen when the truck is new like mine did a 4,000 plus miles, or could happen at 189,001 miles, or any where else for that matter. No way to tell. I carry an xtra one with me in case it happens again. Easy fix, and if it were to go bad somewhere out in nowhere, it could cost a mint to get a tow and have Ford replace it. You can get them new on e-bay for $70-$80 plus shipping.
Old Jul 20, 2003 | 03:19 PM
Ggg6's Avatar
Ggg6
Cam Sensor
Spud, Bring your engine s/n with you to IH. The new cam sensors will not work in the engines that require the old sensors. Yes the terminal metal is different but so is the wiring inside the sensor. I have tried the new style sensor and it didn't work so I tried a new old style sensor and it did work. These sensors go out often enough that most people recomend carring a spare with you.
Old Jul 21, 2003 | 01:25 PM
Spectre23's Avatar
Spectre23
Cam Sensor
Mine just went out last week. I only have 65,000 miles on my '99. The other code my computer was putting out was "E/G/R Pressure Valve ***'y. So the dealer replaced that too. Anyone know what this is? It is my understanding that the Powerstroke doesn't have and EGR like most gas engines do.
Old Jul 21, 2003 | 08:46 PM
KING's Avatar
KING
Cam Sensor
What are the symptoms of such occurance going out, if any?
Also -stupid question here- but do ALL POWERSTROKE DIESEL's have a cam sensor?
Old Jul 21, 2003 | 08:50 PM
Spectre23's Avatar
Spectre23
Cam Sensor
When mine went out, it was a really hot day (105+) and the idle started getting funky. I got on the freeway to drive to the dealership and the truck acted like it was misfiring really bad (which diesels don't do since they have no ignition) and it wouldn't go over 35 mph, then the engine just completely died.
Old Jul 21, 2003 | 11:48 PM
Ggg6's Avatar
Ggg6
Cam Sensor
There are a lot of different symptoms. My truck would die at idle when the engine was at normal operating temp. When it was cold it ran fine. It did this for about two days. then it finally wouldn't start.
75Three90
Texas Chapter
20
Oct 15, 2016 02:09 PM
lesster
27
Jan 18, 2012 10:26 AM
skinsey
Texas Chapter
Mar 13, 2003 12:17 PM
myst
Jan 26, 2003 11:53 AM
