Cam Sensor 1994 Explorer
Old Aug 10, 2004 | 01:18 AM
vtcart's Avatar
vtcart
Question Cam Sensor 1994 Explorer
I own a 1994 Ford Explorer (4.0 pushrod). I have two questions. 1. I had the truck diagnosed for the check engine light being on and the dealer said that the problem was with the cam position sensor. The truck runs fine. If the cam sensor was bad, would the truck even start?
2. If the Cam sensor is the problem, can someone tell me exactly where this
sensor is located?
Old Aug 10, 2004 | 02:33 AM
Bashman's Avatar
Bashman
It is stuck somewhere on the back of the block on 4.0 OHV engines. It will still start but would run like crap since it times the sequence of the fuel injectors. Do the wiring checks for the sensor, most likely bad connection/wiring.
Old Aug 10, 2004 | 09:15 AM
ranger88a's Avatar
ranger88a
I've had them run fine yet set the code. I have replaced the sensor and all is fine. Check the wiring and connections first however.
Old Aug 10, 2004 | 01:46 PM
jddaero's Avatar
jddaero
Check everything first!!!! I can tell you that the part is about $400.00 Not incl labor.
Other models are like $99 and the '94 model we are screwed.
Joe
Old Sep 24, 2004 | 06:26 PM
94FordExploder's Avatar
94FordExploder
Red face Replace it
I just replaced one today. It is a piece of cake, I went to a self serve junk yard they charged me $39 for all the parts I could carry out. It is on the back of the block to the right of the center line. Just unscrew the two phillips head screws R&R and your done no nead to mess w/timing. If you buy the complete sensor it comes (for sh**s and giggles) like a distributer. To me is a waste as the only thing that wears is the top half.
seanj5202
30
Jan 12, 2016 09:54 AM
tbax46
Nov 28, 2015 07:13 PM
mrwrench
Jun 2, 2014 09:15 PM
Paige Haddock
17
Oct 14, 2005 10:57 PM
