Injectors!!!
Old May 9, 2009 | 03:48 PM
stuntman88's Avatar
stuntman88
Injectors!!!
as far as im aware my truck is running great its an 85 one ton dually 4x4 crew cab with a 6.9l but i want bigger injectors anyone know where i can find them???
another question i have is my brakes just aint right i having good pads and rotors, shoes and drums new calipers new wheel cylinders and new master cylinder i also adjusting the rears nice and tight but my pedal is still mushy as hell after i replaced everything i listed it was working pretty damn good for a few days but then i was driving hit the brakes they were hard then went back to mush any ideas please help!!!
Old May 9, 2009 | 05:25 PM
bad12jr's Avatar
bad12jr
If u dont have a turbo injectors wont help much. Just dumping raw fuel out the exhaust.
Old May 9, 2009 | 08:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
stuntman88,
Welcome to FTE and the IDI diesel forum.
If you get any black smoke out of the exhaust, you already have more fuel than you can burn with the amount of air in the engine.
More power would mean you need more air in the cylinders to burn the fuel.
As for the brakes are you loosing any fluid?
Did you change any of the rubber brake hoses?
Old May 10, 2009 | 12:45 AM
johnboggs21's Avatar
johnboggs21
mush means air in the lines somewhere. Take a look at your brake fluid and see if its down any.
Old May 10, 2009 | 09:51 PM
stuntman88's Avatar
stuntman88
i bled the brakes multiple times and yesterday i got under the truck and checked out every line and found there was a pinhole in the line running to the rears thank you im gunna be working on that tomorrow
Old May 10, 2009 | 09:54 PM
stuntman88's Avatar
stuntman88
the hoses werent collapsed and i wasnt really losing fluid but i did find a pin hole not enugh to dumo fluid but enough to were i had no brake pressure and im looking into getting a turbo and wanted to upgrade the injectors also that why i was asking i probably should have stated that before hand my bad and yes i have a lil coal blowing out the exhaust right now i cranked the injector pump a lil less than a quarter turn with the ease of doing that im very pleased witht he result lil but more power and a good smoke when i punch it so im satisfied
Old May 10, 2009 | 11:13 PM
Dave Sponaugle
With a turbo you could turn all that black smoke into power.
Once you have any black smoke, you need more air before you will see any more increase in power.
In fact if the smoke is black enough, less fuel may give you more power.
1/4 turn = 1.5 flats
That is a lot of fuel for a NA motor.
Old May 10, 2009 | 11:32 PM
optikal illushun's Avatar
optikal illushun
mine is about that and i have just a slight gray haze when i mash the pedal. before i did the intake i reckon it would have smoked heavily but i also have G code injectors.
Old May 11, 2009 | 09:49 AM
stuntman88's Avatar
stuntman88
its not very heavy unless i put it to the floor the i get a good puff going i gained a lil power over stock but i wanna look into injector for when i pick up the turbo kit because all that boost ont dont much good unless i got the injectors to give me enough fuel is there a company anyone prefers for 6.9l upgrades?? i know there isnt a whole lot u can do to them but im having trouble finding anyhting
cigarxtc
May 12, 2011 02:26 PM
HISGTO
Oct 30, 2010 04:58 AM
ford f-200
Dec 26, 2009 12:11 PM
Jikiri
Nov 4, 2009 04:36 PM
bluesuedetruck
Dec 13, 2005 06:23 AM
