When towing my travel trailer should I be in overdrive? I have a 30BHDS Jay Flight with a dry weight of 7200. My truck is a 250 crew, V10, 4wd, if that helps.
The 1/2 ton Dodge I got rid of had a "tow/haul" mode. That made it easy you just put in in tow/haul and go. The tranny would go into overdrive when on flat ground at interstate speeds.
I, like Jason, tow in OD until trans hunts, then hit OD button to turn it off and always keep an eye on trans temp gauge. My TT is about the same as yours, weight wise.
