Tow/Haul Button
Old Nov 18, 2016 | 04:54 PM
Nimrod's Avatar
Nimrod
Tow/Haul Button
Not a whole lot of experience with the tow/haul mode. I understand the general concept. The 2001 7.3 had an overdrive button - disabling overdrive I believe. My wife hauled her horse trailer and I don't think she ever used it.
But here is my question - is it ever ok to haul without using the tow/haul mode. The reason I ask is I do tow mostly very light loads. My larger boat total weight with trailer is probably in the 4K range. My smaller boat is very light - probably total rig at about 2k if that. Wife's horse trailer is a different animal as would be my flatbed with tractor loaded.
I have the 6.2 gasser. What are your thoughts?
Old Nov 18, 2016 | 07:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can tow with or without tow/haul. Tow/haul is designed to make driving while towing easier. If you don't like it, don't use it. The truck was designed to be able to tow with or without it. You won't hurt it either way.
Old Nov 18, 2016 | 08:06 PM
Nimrod's Avatar
Nimrod
Thanks Mark!
Old Nov 18, 2016 | 09:47 PM
ssoundwave's Avatar
ssoundwave
It will save your brakes as it turns on engine braking to help you slow down especially when going down hill and slow speeds, I don't think gassers have exhaust break like the diesels but that helps with high speeds
Old Nov 19, 2016 | 06:07 AM
K A M's Avatar
K A M
Using Tow/Haul will hold it in gear longer to prevent straining on acceleration. When slowing it will keep the Torque Converter locked up and down shift to use some of the engine compression to help slow down. Not the same as Exhaust Braking which will add more engine braking when slowing.
Old Nov 19, 2016 | 10:12 AM
gotroxs's Avatar
gotroxs
Ford actually says that it designed for hills and mountains and that is when it should be used.
Old Nov 21, 2016 | 07:03 AM
Tx Hunter's Avatar
Tx Hunter
With a lighter trailer not much difference. With a heavy trailer, it definitely improves the experience. Stretching out the upshifts helps get the rig moving, and accelerated downshifts help to slow it down without having to stand on the brakes as hard.
Old Nov 21, 2016 | 08:59 AM
K A M's Avatar
K A M
Oh and don't tell anyone. When I go to the city and get in heavy traffic I hit the Tow/Haul so I can pull out from a stop into traffic. Be careful that *** end will come loose.
I went test drive a 17 King Ranch. The young salesman tells be to get down on it to feel the power. So I do and it feels ok. So I pull over to let traffic pass. He ask what I'm doing and I say watch this. I put it in Tow/Haul and turn the traction control off. I pull back onto the street and stop. I then launched it and left two black lines about 50ft+ then two short lines when it hit second. He only thought he was the most knowledgable salesman of the Super Duties and now he was educated. He liked that.
Old Nov 21, 2016 | 11:34 AM
porthole's Avatar
porthole
What does tow/haul have to do with that?
Old Nov 21, 2016 | 12:07 PM
K A M's Avatar
K A M
There is no lag when you accelerate into traffic.
Old Nov 21, 2016 | 12:12 PM
porthole's Avatar
porthole
And, what does tow/haul have to do with that?
Tow/haul doesn't change turbo spool up characteristics, or power programming changes.
Old Nov 21, 2016 | 12:13 PM
K A M's Avatar
K A M
Go try it then get back
Old Nov 21, 2016 | 12:41 PM
porthole's Avatar
porthole
Don't have to, forget the question
Old Nov 21, 2016 | 12:42 PM
brdcrtr's Avatar
brdcrtr
I use Tow/Haul a lot in stop and go traffic. It prevents my truck from shifting into a higher gear when going slow so I can just let off the gas to slow down when needed. It acts more like a manual car would in those situations.
This is on an Ecoboost F150. I'm assuming it'd be the same for Super Duties (haven't received mine yet).
Old Nov 21, 2016 | 04:25 PM
fidel.medrano's Avatar
fidel.medrano
technically because tow haul causes the truck to stay in gear longer before shifting this would raise rippums and cause the turbo to spool faster with more available boost. Theoretically...
