360 , 390 spec's
Old May 7, 2009 | 09:19 PM
alfuson's Avatar
alfuson
360 , 390 spec's
what is the the differnce between the 360 and the 390 motor is it the crank or the rod lenght or what i have a 360 and want to rebuild it and make it a 390 can you please help me
Old May 7, 2009 | 11:56 PM
393STROKER's Avatar
393STROKER
There`s some info that is good in the post @ the top of the forum.READ FIRST:FE BIG BLOCK FREQUENTLY ASKED QUESTIONS by RATSMOKER
Old May 8, 2009 | 12:12 AM
85e150's Avatar
85e150
360 = 390 with 352 crank, longer rods, and 390 2v car pistons or something very similar, that sit down the hole .120 or so. No other diffs, as installed in PU's.
Add the 390 crank and rods, and the 360 pistons, or 390 2v (car) type pistons, and you have a 9.5 or so compression 390.
You can also add more stroke, to a max of about 445 with the 4.05 bore engine.
The FAQ is an excellent place to start. Then, go through the threads. There are "360 to 390" posts every month, sometimes two at a time. This has been gone over dozens of times in the last year alone.
Old May 25, 2009 | 11:55 AM
alfuson's Avatar
alfuson
360vs390
thanks for the information on the 360 vs 390
Old May 25, 2009 | 06:02 PM
7d2 Custom's Avatar
7d2 Custom
If you want to go a litttle bigger, a 428 crank in a 390 is a 410...torque with a capital "T"
Old Jun 3, 2009 | 08:58 PM
BroncoDually's Avatar
BroncoDually
Wink 360 , 390 spec's
Speaking of the 360 & 390,Question:How much can I Overbore & Stroke the 390 Engine,Without the risk of Engine Block Damage,What would the c.i.d. be (4___ cu. in.) with max Overbore & Stroke on the 390,Would increasing the throw on Stock 390 Crankshaft (3.780") or use the Crankshaft from the 406-428 SCJ (Super Cobra Jet) for more cu. in. from 390
Old Jun 3, 2009 | 11:10 PM
85e150's Avatar
85e150
See your other post, and see the FAQ's regarding the bore/stroke of different FE's.
ford_maniac-68
Mar 4, 2017 10:53 AM
WW2N
Sep 18, 2016 05:27 PM
Vinford
Feb 13, 2016 10:05 AM
bigred.102
Mar 27, 2011 10:51 AM
lilpig88
May 30, 2003 07:18 PM
