360 , 390 spec's
what is the the differnce between the 360 and the 390 motor is it the crank or the rod lenght or what i have a 360 and want to rebuild it and make it a 390 can you please help me
There`s some info that is good in the post @ the top of the forum.READ FIRST:FE BIG BLOCK FREQUENTLY ASKED QUESTIONS by RATSMOKER:-X0A6
Originally Posted by alfuson
(Post 7477893)
Add the 390 crank and rods, and the 360 pistons, or 390 2v (car) type pistons, and you have a 9.5 or so compression 390. You can also add more stroke, to a max of about 445 with the 4.05 bore engine. The FAQ is an excellent place to start. Then, go through the threads. There are "360 to 390" posts every month, sometimes two at a time. This has been gone over dozens of times in the last year alone. |
360vs390
thanks for the information on the 360 vs 390
If you want to go a litttle bigger, a 428 crank in a 390 is a 410...torque with a capital "T"
360 , 390 spec's
Speaking of the 360 & 390,Question:How much can I Overbore & Stroke the 390 Engine,Without the risk of Engine Block Damage,What would the c.i.d. be (4___ cu. in.) with max Overbore & Stroke on the 390,Would increasing the throw on Stock 390 Crankshaft (3.780") or use the Crankshaft from the 406-428 SCJ (Super Cobra Jet) for more cu. in. from 390
See your other post, and see the FAQ's regarding the bore/stroke of different FE's.
