360/390
Old Feb 12, 2016 | 10:34 AM
Vinford's Avatar
Vinford
Is there any visual way to tell the difference between a 360 and a 390?"
Old Feb 12, 2016 | 11:30 AM
Gembone's Avatar
Gembone
No, you have to measure the stroke.
Old Feb 12, 2016 | 01:29 PM
crazed87bronco's Avatar
crazed87bronco
Nope no way to tell them apart by looking at them. You will need to measure the stroke 3.50" is a 360 3.75" stroke is a 390
Old Feb 12, 2016 | 01:36 PM
HIO Silver's Avatar
HIO Silver
... And here is how to measure: https://www.ford-trucks.com/forums/7...ml#post6830607
.. And here is one with pictures! https://www.ford-trucks.com/forums/9...l#post13616693
Old Feb 12, 2016 | 05:10 PM
jowilker's Avatar
jowilker
I have done it with the wooden dowel, and the white jacket wire from a 12-3 section of house wire. Both will work, the wire is smaller and easier to work with. IMHO
John
Old Feb 13, 2016 | 02:41 AM
JEFFFAFA's Avatar
JEFFFAFA
Not from the outside with it still in the truck. If it's already removed you can pull the oil pan and tell by the shape of the crankshaft's counterweights. Between a 360 and 390, the 360's counterweights are squared off. Flat on the outer ends. The 390's are tapered.
Old Feb 13, 2016 | 03:08 AM
bert cook's Avatar
bert cook
i thought if you looked at the back of the crankshaft phlange one was round and one had a half moon notch cut in to it
Old Feb 13, 2016 | 09:58 AM
KsHighboy's Avatar
KsHighboy
On the rear flange of the crank there will be a square notch or a half moon and also both on the same crank. All the 390s Ive seen have just had the square notch. Ive seen 360s with just a half moon and Ive seen them that have both a notch and a half moon. Not sure if that is a guaranteed way to tell but that has been my experience.
Old Feb 13, 2016 | 10:05 AM
MIKES 68 F100's Avatar
MIKES 68 F100
I wish I had a Dollar for every time that was asked here ...lol
gcfisher75
Jun 22, 2004 08:16 PM
bigtymer77
May 11, 2004 02:29 AM
Boltgunner
Feb 29, 2004 05:31 AM
bhaider
Dec 7, 2002 02:48 PM
