Harmonic Balancer?
Old Jun 2, 2009 | 10:57 AM
66_in_ky's Avatar
66_in_ky
Harmonic Balancer?
Hello Everyone,
I'm preparing my 428 long block for installation in my 66 F250 with auto transmission (COM). I'll have a detroit balanced flywheel. I have two parts engines (1966 352 with COM transmission and 1974 360 with 4 speed transmission). Will the harmonic balaancer on either of the doaner engines work on the 428?
Old Jun 3, 2009 | 01:11 AM
johnboy427's Avatar
johnboy427
I don't believe they will work the 428 and the 410 were the only FEs that were externally balanced so that balancer will not have the counter weight.
-Johnboy
Old Jun 3, 2009 | 05:43 AM
66_in_ky's Avatar
66_in_ky
Thanks johnboy427. I'll find one for a 428.
Old Jun 3, 2009 | 01:28 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
-Johnboy
All FE balancers are zero balanced so either one will work for you. 410 and 428 flywheels/flexplates are counterweighted for external balance. I'd choose which ever balancer looks the best and fits with your pulleys. JB must be thinking of the 428SCJ crankspacer with the counterweight on it. Not the balancer itself. The 428, 428CJ and 410 use the same crank spacer as any other FE would except the SCJ as noted. Check for cracks in the rubber on the balancers. If it's cracked it can slip after time. Aftermarket ones from Pioneer are inexpensive replacements.
Old Jun 4, 2009 | 06:46 AM
66_in_ky's Avatar
66_in_ky
FFR428 - I also asked the mechanic who rebuilt the 428 and he said I could use the balancer on my 66 352. Thank you for the explanation.
TPyle
Apr 12, 2014 04:45 PM
TPyle
Apr 2, 2014 07:32 PM
MIKEDEL
Dec 15, 2011 06:43 PM
ChrisAdams
Mar 12, 2011 07:09 PM
nikwave
16
Jan 8, 2005 05:26 PM
