Coolant filter ?s
Old May 7, 2009 | 11:55 PM
SHAWN056.0's Avatar
SHAWN056.0
Originally Posted by joe blow
Like Beachbum said......
Everything else can be made (except for the base obviously). The "T" that splices into the degas bottle is a simple brass 3/8" "T".
The "T" that scavenges coolant from he 3/4" heater hose on the RH side of the engine is a 3/4" to 3/8"...that is alot of reduction and alot of potential leaks....brass is very hard to seal once you get into the smaller diameter stuff....normally breaks if tightened too tight.
By the time your done your going to have 2 lbs of brass free floating or tapping on the RH valve cover if not secured (but I am pretty sure you thought of that).
The dieselsite kit is basic, but what sold me is the CNC(machined) 3/4" to 3/8" "T" that splices as the above mentioned. It is clean looking and it is light (ounces). I have seen pics of the menagerie of brass needed to complete this "T" needed. In my opinion it looks sloppy, heavy and almost like I am looking underneath someones sink at their plumbing.
Just my opinion
appreicate the info. found a brass t that would fit the big hose, was a little tight but it worked and it's not too bulky either. thanks for all the info guys. check that one off in the to do list.
Old May 8, 2009 | 08:10 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by southbound35west
i did not have time to chase parts down either, i bought the coolant system from dieselsite and i love it................bilstein shocks r next........
Here is where I bought my Bilstein Shocks several years back.
http://www.eshocks.com/
Great price and fast shipping.
When I bought mine, they shiped for free when you bought 4 shocks.
Check them out and compare. Call them if necessary, but they are a high volume Bilstein dealer.
Save your receipt, as Bilstein has a lifetime warrenty through Bilstein directly.
troy676
Feb 21, 2014 05:41 AM
StanleyZ
6.4L Power Stroke Diesel
Nov 7, 2012 12:01 PM
DieselVol
Aug 13, 2012 01:49 PM
95schauf
Mar 3, 2012 04:37 PM
mickapoo
Feb 14, 2006 06:09 PM
