No tricks. Just get ALL the bolts loose. There are a couple in the back corner under the HVAC box that are a little tricky to get to. Have to feel for them.
I have a oil leak on the pass rear, i can not see. It seem like it is a volume of oil issue, as when i run it hard and stop it is worse. Just wondering if anyone else was haviong leaks back there.
It was damp with oil back there. No I didn't get it off, had it loose and high enough to see in, but couldn't get it out. I traded it in on a 7.3 a day later, the wrist pins were making noise.
