Modular V10 (6.8l)
fixed?
Old May 21, 2009 | 07:06 PM
howler4x4's Avatar
howler4x4
fixed?
Cold leak at right exhaust manifold, fixed under purchase warranty by dealer's mechanic. He had to remove some broken studs.
It came back in 5 weeks, way louder. Mechanic says one of the nuts loosened, and the gasket burnt. I was 1/4 way through a 600 mile trip when it let go, so he had to replace the gasket.
It seems to be fixed, nice & quiet. But... looking at it I can see 2 bolts were used. Could be more, I can only see 4 of the 10. The bolts do not look like stainless steel.
How much of a problem is steel bolts? and how much time do I have to replace them with stainless studs? Can it wait 2,000 miles? 2 months?
This is a bad time for me to take the time to fix it right myself.
Old May 21, 2009 | 09:37 PM
BareBones's Avatar
BareBones
Well, aren't the ones that were not replaced eight years old? You'd think the old steel would be a higher replacement priority than the new steel.....
Old May 21, 2009 | 10:19 PM
howler4x4's Avatar
howler4x4
The old, original studs are stainless. I'm concerned about (non-stainless) steel bolts causing problems with the aluminum head.
If I had time to do it now, I could remove the manifold without much trouble. Will I risk trouble by waiting 2 months / 2k miles?
Old May 22, 2009 | 01:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Use anti-seize, and it's all good.
2 months won't kill you.
krewat's Avatar
krewat
powerstroker100
Feb 22, 2012 11:47 PM
Velislide
May 8, 2009 02:55 PM
Gage2502
Aug 3, 2008 03:38 PM
bubbalou
Apr 10, 2006 10:05 PM
PigFarmer
13
Jan 6, 2003 07:24 PM
