Testing Balljoints
Old May 5, 2009 | 08:00 PM
DieselCamper01's Avatar
DieselCamper01
Testing Balljoints
Can someone tell me the procedure for testing my balljoints? Do you jack it up so the pressure is off or on the balljoints? How much movement would I likely see? Can I do this myself or do I need a helper?
Sorry about all the questions guys and gals.
Old May 5, 2009 | 08:12 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I have always been told to jack up one side of the front end about 3" off the ground then put a 2x4 under the wheel and pry up and see if you get any movement you should have no up and down play at all.
Old May 5, 2009 | 08:34 PM
DieselCamper01
I jacked it up on the axle and could not get the passenger side to move at all. Unfortunately the lower drivers side moved a fair amount. And I am getting a clunk under braking and also under acceleration so I think I found my culprit. It felt like the clunk was coming from the drivers side too.
Old May 5, 2009 | 08:47 PM
F350-6's Avatar
F350-6
Doesn't have to be 3" up. I lay the 2x4 parallel with the tire and place a long pry bar across it and under the tire. The 2x4 acts as a fulcrum and gives you leverage to pry the wheel up and down. If you see slop in the ball joints while doing this, it's time for new ones.
Old May 5, 2009 | 08:49 PM
SuperDoodie's Avatar
SuperDoodie
Another sign your balljoints are going out is that you have tire wear on the inside of your tires.
I was having the same clunking noises, even after doing ball joints. I replaced the sway bar bushings in the front and the noise was gone.
DieselCamper01
Thanks guys. I will be doing one side at least soon it looks like.
Old May 5, 2009 | 08:51 PM
DieselCamper01
I will see what the balljoint replacement does first then go from there. Thanks for the input. MOney only goes so far these days it seems. lol
Old May 5, 2009 | 08:57 PM
SuperDoodie
I hear ya there!
Energy suspension bushing kits are about $40 too
Old May 5, 2009 | 08:58 PM
DieselCamper01
Hey thanks! $40 is not too bad.
Old May 5, 2009 | 09:19 PM
Excursion4X4's Avatar
Excursion4X4
Jay,
I've done the balljoints on my Ex already. PM me if you would like any Help/company.
Old May 5, 2009 | 09:26 PM
DieselCamper01
Originally Posted by Excursion4X4
Jay,
I appreciate that Dale. Not sure exactly when I will do this but it needs to be soon I think. Not sure how bad is bad so I do not want to push it. We may need to do a mini G2G. Mike (Ford79) offered his help also and has all the tools. Maybe we could load up and head to his place (just across the border in WI). I will keep you posted.
Old May 5, 2009 | 09:29 PM
Excursion4X4
Sounds good, Like some of the other folks here I currently am out of work, So time is usually no issue.
Old May 5, 2009 | 09:52 PM
DieselCamper01
what kind of work you into Dale?
Old May 6, 2009 | 12:43 AM
mndiesel's Avatar
mndiesel
Jay,
Let me know if you need help and when you are going to do it. I would like to see this done and halp if I can.
Old May 6, 2009 | 07:52 AM
DieselCamper01
I will let you know Tom. Thanks
