I never use a 2x4 or a prybar, just jack the wheel up and grab the tire and try to move it. If you feel any movement, it's new balljoint time.
Oddly enough, just after I bought my truck I realized the lower driver's balljoint was shot, so I replaced everything on that side (ESOF seals, upper/lower ball joint, etc). but the pass. side was fine so I left it alone. Checked everything out about a month ago, and the pass. side is still nice and tight.
Jay- you'll probably need a press to get the upper (IIRC) ball joint out- I was able to drive one out with a hammer, but the other one needed pressed out. Also a neat trick for getting the ball joint to pop loose if it's stubborn- drive a pickle fork in on the upper ball joint nice and snug, then hit the knuckle with a good sized hammer. The vibration from the hammer along with the pressure from the pickle fork will pop the ball joints free.
Thanks Chase. I was able to move the drivers side lower by hand also so I am just going to do the upper & lower on that side for now. I appreciate the tips and feedback.
Originally Posted by Excursion4X4
DieselCamper01;what kind of work you into Dale?
Railroad conductor. was a wrench for years b4 that tho.
I did not realize they had orchestras on the railroad.
Jay, don't know if you were told or not but try to get the Moog ball joints, their not that much more and their greasable and their much more durable. Most of those other ones just come with a one year warranty, the Moog's you get a better warranty.
It your choice Jay, the reason I suggest it is theirs not to much of a difference in price, around here anyways,maybe 5 bucks. The reason I go heavy duty is our motors are heavy and its piece of mind for me. Good luck whatever you go with..
Stop it you two! Your killing me here! Just when I had convinced myself you change my mind again! Ed says he can get me greasable Motorcrafts for about 1/3 the price of Moogs.
Well, if their Motorcraft greasable's, they should be ok, I'd say shoot for them, never knew Motorcraft had greasable's.. If Ed said their fine, go for it...
I appreciate that Dale. Not sure exactly when I will do this but it needs to be soon I think. Not sure how bad is bad so I do not want to push it. We may need to do a mini G2G. Mike (Ford79) offered his help also and has all the tools. Maybe we could load up and head to his place (just across the border in WI). I will keep you posted.
Load up and head on over. You are all welcome here.
I'd say if Ed can get you the Motorcraft greasable's for 1/3 the price of Moog's, go for it.
Did you ever check out another site sponsor, Rock Auto? Rock Auto Parts Catalog
